Emanage Ultimate assistance - larger injectors and MAF
Old Aug 31, 2008 | 05:10 PM
mtrai760's Avatar
'Trynna' is not a word
I installed a EU yesterday in my 98 Maxima, and I have a couple of issues/questions.
Issue #1: Nevermind, figured this question out myself Is anyone running a Z32 MAF with the EU? I tried selecting VG30DETT for my MAF, but it will not accept it in the menu screen, it just goes back to blank (stock). Anyone have a similiar issue? <--- Uses the same MAF setting for the VQ30DET as the VG30DETT, that is why you cannot select the different MAF, it is not different for EU programming purposes.
Issue #2: I'm having a problem with injector lag time with my Z32 injectors. After doing a LOT of research, I came across 2 answers for lag time on Z32 370cc injectors, .58ms, and from calling Deatsch Werks, 1.4ms. I tried both, and the issue I am having is running way to rich at idle. At .58ms, I am running at 11-12 AFR. At 1.4ms, I run at 10-11 AFR. I tried playing around with the lag time, but I want to set it correctly, not guess.
I am running 370cc Z32 injectors cleaned and balanced by Deatsch Werks. They tested between 411cc-418cc at 43.5psi. I am running stock fuel pressure (34psi). Anyone have any suggestions? I would think that the stock ECU would compensate, but the AFR is staying really rich. I do not have any adjustments programmed into the EU that should be affecting idle (or anything below 50% throttle for that matter). Do you have to set your stock injector size and lag time in the boxes for that info? I set the stock size in (260cc) but it made no difference.
Other than that, car starts and runs fine, albeit really rich. I am currently running version 2.20 on the software. We have to use the VQ30DET setting, does anyone know if this is actually using VQ30DET specs, ie a different MAF and injectors than the A32 Maxima?
Thanks for any help, I'm eager to get out and start doing some tuning runs!
Old Sep 1, 2008 | 08:43 AM
MOHFpro90's Avatar
Not sure if this is of any help, but if I recall correctly, don't you have the option of tapping or intercepting the MAF signal? Which did you do? I haven't used or seen the software/interface so I am not sure how it correlates with the option but maybe that has something to do with it?
Not sure on tha A/F issue. But just from reading what you wrote, I would say it would have to be higher to make it leaner. But I really have no idea.
Good luck man!
Old Sep 1, 2008 | 08:46 AM
mtrai760's Avatar
You do have the option of tapping or intercepting, I intercepted the signal since I am running a Z32 MAF.
I would like to get the injector program set correctly for the larger injectors, I'd hate to guess and be wrong.
Old Sep 1, 2008 | 01:01 PM
maximase86's Avatar
I love lamp.
Matt, you might give Zach a call. He had a similar problems. Can't remember off the top of my head what he did to fix it. Worth a shot.
S
Old Sep 2, 2008 | 06:16 AM
mtrai760's Avatar
Maf issue is figured out. The EU uses the same MAF settings for the VQ30DET as the VG30DETT, therefore you cannot select the VG's MAF.
Old Sep 2, 2008 | 07:54 AM
liqidvenom's Avatar
brotherhood of tq
so when you select the vq30det as the engine it goes on the assumption you already have the z32 maf?
Old Sep 2, 2008 | 08:00 AM
mtrai760's Avatar
Either that, or the setting is just exactly the same between the two MAF's.
In the EU menu, under Vehicle Selection
Selecting VQ30DET under engine automatically enters
Airflow meter type: Hotwire
Airflow meter spec: NS_HW2
for the MAF.
If you select VG30DETT, it enters the same MAF settings.
Old Sep 2, 2008 | 09:46 AM
liqidvenom's Avatar
brotherhood of tq
ahh...
I hope this isnt cluttering up your thread.... but
I have two questions that I have after reading the dandy-max write up last night.
1) In the newer software does the vehicle speed limiter and the rev limiter work using the settings in the EU or would you have to go about getting the rev limiter to work the way that dandy explained.
2) What would be the issue with having the eu do auto tune full time with a wb02 hooked up? I couldnt find a setting that allowed some sort of safety net if the wb02 failed though. i would think having it being a live tune would be a good thing to have.
Old Sep 2, 2008 | 10:04 AM
mtrai760's Avatar
ahh...
1) Speed limiter cut setting always worked I believe. I'm pretty sure (95%)you still have to raise the rev limiter per Dandy's method, though I have not tested this yet. I have found similiar things in other applications of the EU and the rev limiter cannot be raised by any other method.
2) The Auto tune feature is only used to get you 'close' to a decent tune. If you left it on all the time, it would always be changing the tune on you, and your right, it has no failsafe, which could be a very bad thing if your WB02 failed. The autotune by itself is not going to get you the best power out of your setup.
Old Sep 2, 2008 | 07:26 PM
DandyMax's Avatar
3.5 in the works
Correct on both counts.
I see you figured out the MAF, and yes it's because they are the same setting in the software (HW-2).
As for your idle richness, it's a little odd because at stock fuel pressure the 370's shouldn't be so big that the ECU can't compensate once it's in closed loop. You should be able to run with only a minimal or no lag adjustment. Are you sure it's going into closed loop? Have you checked other parameters such as the water temp readings, do they come up to normal at warm idle? The ECU will need to see a normal water temp before it goes into closed loop (ie not what it thinks is a cold state).
Also, this is something I probably should have put in the writeup but there's a lot of confusion about the injector boxes. The reality is that for 99.99% of all setups there is NO need to put before/after sizes in the injector boxes. The reason for this is that doing so does not automatically activate a global scaling factor. IMO Greddy dropped the ball on this. It would have been easy to just apply a global scale factor but no, instead that factor will only apply to non-zero cells in the fuel maps. And given that you can add or subtract up to 20 ms of pulse width directly in the maps it makes that factor redundant and confusing. SO, the summary is that if you have larger injectors, you simply have to program the fuel maps to pull fuel and disregard the sizing boxes. The lag setting is a different issue and may help for significant upsizings but in the case of your 370's it shouldn't need a huge adjustment, 1.4 ms seems like a lot for that size injectors, and I still think the ECU should be able to adjust reasonably for that size. What happens if you leave the lag at zero? And until you know that your ECU is definitely in closed loop at warm idle I would look at that first.
Old Sep 3, 2008 | 07:03 AM
mtrai760's Avatar
Thanks for the reply. The car runs just fine with the EU removed, on the 370cc injectors, so I do find it odd that it does not run exactly the same with the EU connected. Everything is fine other than the rich idle with the EU connected.
I did try making no adjustments at all to the injector size, and it still seems to run rich, 13 or so on the AFR. I did check to make sure it was in closed loop before I started worrying about it, but then again, it idles find in open loop when warming up right around 14.7-15.0, so again, a little confused at the change when the EU is hooked up.
I do have the coolant senser tapped on the ECU. I am running the coolant temp and IAT's to the EU right now, no knock sensor.
That is good information to know about the lack of scaling by the EU with larger injectors. I did find it interested also that the EU does not automatically enter the 'before' injector size for the VQ30DET. I checked the VG30 and it enters 370 automatically. Not sure what affect this has, just something to be aware of I guess.
I read online that a few people (non-maxima) were having minor issues with the newest update to the EU software, so I may try going back one revision to see if that makes a difference.
I am also considering trying to tune out the rich condition at idle myself. Since the stock ECU will negate any changes to the closed loop map over time to maintain a 14.7 AFR, it should really make a difference long term. I am just concerned about having to adjust things that really shouldn't need to be adjusted. I like to go by 'Do it once, do it right'. If I was NA, I wouldn't be quite so worried, but I have less of a margin for error running 10psi of boost.
I won't have time to mess with it again until tomorrow, I'll post back with results, hopefully this can help someone else in the future.
Old Sep 4, 2008 | 07:31 AM
DandyMax's Avatar
3.5 in the works
And you've verified that your coolant temps are reading properly with the EU and that you don't need to switch JP13 around? Also, not to be a jerk but how do you know you're in closed loop?
I have also heard bad things about the newer versions, I would likely use v 2.00 and nothing newer, most of the newer updates have more to do with the V-manage and fixes for other cars anyway.
If you can't get the warm idle to 14.7 on it's own, then pull fuel on the I/J map or the airflow map and it will bring the ECU back into the range of its adjustability, such that it can maintain 14.7 on it's own starting from the new base point you've essentially created. You shouldn't have to worry about higher load/rpm site tuning (ie WOT/full boost) in that neither the EU nor the stock the ECU should change anything on you once it's tuned/programmed (open loop operation).
Old Sep 4, 2008 | 08:22 AM
mtrai760's Avatar
No problem, I verified that I was in closed loop with my scan tool, and double checked the temps against what the emanage was displaying to make sure everything was okay. It was kinda cool out and my hood was open, I never saw my water temp get over about 185-190, and my fan never came on, so I do not know if I am going to have to change my jumper setting yet, but I was keeping a close eye on it just in case. I didn't try driving the car due to it running so rich, I wanted to get the injector issue figured out first.
I am a little confused as to why the car runs fine with the EU unhooked, but rich with it connected. I have not had time to mess with it any further, I am going to try again tonight, after I change the version over to 2.00. I'll document everything I do and the results afterwards. I am going to try driving it with the injector settings stock, and see if the ECU can tune out the excess fuel. If not, then I'll try tuning it out in the injector map like you recommended.
Thanks for your help, that writeup you did is one of the greatest contributions ever to the Maxima community.
Old Sep 4, 2008 | 05:24 PM
mtrai760's Avatar
Okay, still having some issues...
First off, I went back to version 2.13 on the emanage (verified on system and laptop). I took out the injector size adjustment, though I played around with this some more and the car just idled like crap, so no adjustment on that for the listing below.
Car began overheating, so I had to set jumper 13 to open, problem solved.
Still running too rich at idle, and while cruising. AFR goes between 10.5 - 13.0 at idle, and between 12.5 - 15.0 while cruising under a light load. Not good.
I am having trouble getting settings in the I/J adjustment map or the airflow adjustment map to do anything. I have all my front panel jumpers on, with the I/J adjustment map 1, Airflow adjustment Map, and AFR adjustment map all selected.
First off, using the AFR adjustment map set to adjust for relative pressure, I set the AFR to 14.7 at everything below 0 psi of pressure, up to 3500 RPM. I then started the car up and waiting for a few minutes. Temperature was at 90 degrees C, and my AFR target was set to start after 60 degree C. Still no adjustment to the I/J map. I then tried driving the car at a slow, steady pace, and again, no adjustments made by the EU.
I datalogged the run and no adjustments were ever made. WTF? I checked, double checked, and triple checked everything, and still no adjustment.
Next I tried manually making adjustments to the I/J map, and still no affect on my AFR.
So, what am I doing wrong?
I am assuming I should be seeing the EU make some sort of adjustment to the I/J map, which is how I have the EU setup.
Old Sep 4, 2008 | 07:39 PM
mtrai760's Avatar
I thought I had it figured out for about a minute, but no. Okay, I cannot get the auto tune to change the maps at all, that is my current issue. I finally got my idle tune leaned out some, but it's still not changing my maps using the autotune feature. I thought it was the throttle percentage I had set, but I tried reducing it to 0 and it made no difference.
Old Sep 4, 2008 | 11:34 PM
mastercater7's Avatar
VQ35 FTW
Dan, I am going to have to disagree with you about injector settings. I was having major problems with my fuel settings. Just like Matt, my car ran real rich once the EMU was installed. You must change the injector before and after size to correct these problems. Also, I was so rich that I had to pull ridiculous amounts of fuel to raise the damn a/f ratio to even get decent gas mileage. Also, the a/f ratio would fluctuate a lot on me (definitely not good for FI). Once I changed the I/J before and after, minimal fuel had to be pulled, and the a/f stayed correct.
Old Sep 5, 2008 | 06:14 AM
mtrai760's Avatar
Drove with it still installed to work this morning and boosted twice to 4-5psi. No changes at all on the map from the autotune.
Old Sep 5, 2008 | 07:57 AM
DandyMax's Avatar
3.5 in the works
Are you using duration settings for fuel? There's a bug in the EU (I found out after I did the writeup) whereby the AutoTune will not work with durations but will work with duty cycle. This creates a problem however, in that the rev limit extension has to be done with duration, meaning it's probably best to skip the auto tune and manually tune using durations, since using DC to auto tune and then flipping units doesn't seem to be calculated correctly by the EU. (Unless of course you don't care about the rev limit then just use DC).
Sorry I wasn't sure but is this your only issue now at this point? You are able to make adjustments manually on the I/J maps, it's just the auto tune?
Which version of the software/firmware are you using? I have not tested the newest versions but as of v 2.00 I am confident what I stated above applies based on testing/datalogging I have done in the past. The before/after boxes are applied but only create an effect on non-zero cells in the map. When I tried to input before/after sizes only without making adjustments on the fuel map, it did absolutely nothing, because it's a multiplier (ie something times zero is always zero). I suspect the reason you had to pull minimal fuel (ie input smaller numbers into the fuel map cells) after putting in the before/after boxes is because of the multiplication with the scale factor. So as an exaggerated example you could have either left the before/after boxes alone and pulled 5 ms directly on the I/J map or entered before/after sizes as 290/550 and pulled 2.64 ms in the map, same end result (550/290*2.64=5).
Old Sep 5, 2008 | 08:06 AM
mtrai760's Avatar
Are you using duration settings for fuel? There's a bug in the EU whereby the AutoTune will not work with durations but will work with duty cycle. This creates a problem however, in that the rev limit extension has to be done with duration, meaning it's probably best to skip the auto tune and manually tune using durations, since using DC to auto tune and then flipping units doesn't seem to be calculated correctly by the EU.
Sorry I wasn't sure but is this your only issue now at this point? You are able to make adjustments manually on the I/J maps?
I am using duration and not duty cycle, guess that is the issue with the autotune, makes sense now. I was ready to tear my hair out over that one . I am still having issues with running too rich going into idle. I am still a little miffed as to why my idle is perfect with no EU, yet it requires adjustment with the EU. I am also getting some decent backfires when I let off the throttle with the car still in gear. Normally this would result in the AFR going to reading pure air, but now the reading occilates and I get multiple little backfires I can hear. I guess this is tuning though...
Old Sep 5, 2008 | 08:29 AM
DandyMax's Avatar
3.5 in the works
Unfortunately I don't have a definitive answer for that one except to tell you what my suspicion is. My suspicion is that over the several iterations of new SW/FW as well as hardware (new board versions) Greddy has made changes to the injector drivers/control logic etc. I am hearing more and more now from people that are complaining of the same thing, however back when I installed my old version B board and software I had no such issues, idle was pretty much the same (discounting any effect of bigger injectors etc). And the same for other cars in which I've installed EU's, but again most were earlier versions.
What does the reading oscillate between? Might need to see your maps and a datalog with AFR to narrow that one down...
BTW which WB and pressure sensor are you using and do you have both inputting directly into the EU?
Old Sep 5, 2008 | 08:45 AM
mtrai760's Avatar
I purchased my EU brand new from another forum member who had held onto it for quite a while, so it is an older one, version C.
I have an Innovate LC-1 Wideband controller with the XD-16 gauge. I pulled the sensor and did a recalibration before I started up the car for the first time with the EU installed. I am also running the Greddy pressure sensor, both are connected to the EU using the option ports, with the LC-1 outputing a wideband signal (has two lines, wide and narrow output).
My XD-16 gauge has two readouts, one for AFR, and one that is just a percentage. It used to go to 20%+ when I was declerating in gear with no throttle input, and flash O2, meaning that it was reading normal air. With the EU connected, it stays in the AFR reading, and goes from whatever I was cruising at, to 40-60+. It is a digital gauge so it is hard to get a good reading, it flashes by pretty quickly back and forth.
I tried to datalog a run this morning, but when I tried to pull it up, everything was blank. Guess I'll do another run on the way home.
Old Sep 5, 2008 | 09:12 AM
DandyMax's Avatar
3.5 in the works
Hmm.. maybe it's more a SW/FW issue then?
Ok, I am familiar with that combo, just installed one a few weeks back. The datalog would be more useful though, track it through various rpms, see what the MAF and TPS are doing etc.
Did you hit Start on the datalogger?
Old Sep 5, 2008 | 01:45 PM
mtrai760's Avatar
SF/FW? Drawing a blank on that one...
Yes, I hit start, I'm an EU newb, not an EU idiot!
I think I screwed it up by shutting the car off before hitting stop on the laptop.
Old Sep 5, 2008 | 05:58 PM
VQ35 FTW
Actually Dan, my idle A/F changed and my A/F went from a 10.5 to a 12.7 at WOT once I changed injector settings. I am running version 2.16. This was all before I touched I/J maps and they were all at 0.0
Old Sep 5, 2008 | 06:31 PM
DandyMax's Avatar
3.5 in the works
Hmmm very interesting!! OK good to know, thanks. As I said I hadn't tried the newest versions, only 2.00, I have moved on from the EU and haven't been testing out the newer ones as I don't even have an EU anymore. But that's good, that means Greddy has changed the programming, they probably had enough people complaining the scaling wasn't working.. lol
sw/fw = software/firmware, and yep, that would do it.. lol
Given the above, maybe you want to give 2.16 a shot again?
Old Sep 5, 2008 | 07:03 PM
mtrai760's Avatar
Finally made some progress tonight!
I changed the setting over to duty cycle, and the autotune started making adjustments immediatly. I set the target to 14.7 from 500 rpm to 2000 rpm at everything below 0 psi of absolute pressure. I then let the car idle for a few minutes while it made adjustments, and then took it for an easy drive.
I noticed it was making constant corrections, so I let it idle again, and then raised the auto adjustment limit above 60% throttle, and went back and smoothed out the adjustments that had been made. Seems a lot better, and it fixed the in gear deceleration issue I was having with my AFR. Duty cycle was pulled -15% to -5%.
Next I made a couple of low boost pulls to see how it adjusted my AFR under pressure. Max boost I hit was 6 psi (I was trying to keep it legal) on my way home, and the I/J map was adjusted accordingly.
I am going to get the whole map tuned using duty cycle, and do plenty of data logging until I am very comfortable with the EU. Then I will switch over to duration and work on tuning that up to the stock RPM limit, and then try raising the rev limit. I want to know what I am doing and have some more experience before I try that. While I wouldn't mind swapping in a VQ35, I have dumped enough money into the car for now, I don't want to have to buy a new motor because I screwed up the tuning
Old Sep 23, 2008 | 09:33 AM
liqidvenom's Avatar
brotherhood of tq
glad you are able to make some progress, ive been doing my eu wiring slowly since this is my dd and im strapped for time.
question about the innovative... is it possible to have it output two wideband outputs? i noticed that its preprogrammed to deliver a wide and a narrow.
if it only outputs one wideband reading are you just using that one wideband reading to feed both the EU and your gauge?
Old Sep 23, 2008 | 11:39 AM
ObsidianIce69's Avatar
Yes. You just need to go into the software and change that configuration. It will output pretty much whatever you want.
Old Sep 23, 2008 | 12:46 PM
mtrai760's Avatar
The innovate LM-1 includes the normal output to the gauge, as well as a wideband output, and a narrowband output. 3 outputs total.
Old Sep 24, 2008 | 01:07 PM
Sorry i think i was vague in my post. Liquidvenom...What i should have said..is Yes...it can output 2 wideband readings. I don't know if you have a LM-1, LC-1 or whatever but i know the LC-1 can do two wideband outputs and per mtrai760 the LM-1 can as well. you should be golden. You just need to go into the software and change the setting.
and to Mtrai760....how's the tuning been going? I'm quite interested in the autotuning and will be trying that when I eventually get the car back together.
Old Sep 24, 2008 | 01:14 PM
mtrai760's Avatar
Tuning is going good but slow, (no fault of the EU) thanks for asking. I have not been able to log any runs for a couple of weeks, too busy with other things. The temperature is dropping rapidly here in the Pacific NW, so I may have to start over in some areas of the Map. The car is running stronger than ever though.
Old Oct 10, 2008 | 04:32 PM
liqidvenom's Avatar
brotherhood of tq
I just tried the same thing with my car using the settings you told me over the phone. i had to play with the ms delay a bit and set it at .18 to get my car to idle at 14.5-14.7.
if i left the ms at 0 then my car would have a a/f of 18 or so.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 6, 2015 02:34 PM
ballerchris510
Sep 10, 2015 09:35 PM
