Anyone with water cooled turbo?
Old 09-21-2008 | 11:16 PM
Maxpwer's Avatar
No turbo, no care!
Is anyone here running a turbo that is water cooled or ran one in the past?
Old 09-22-2008 | 09:36 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
why wassup, both of mine are water cooled and the t3 i had was as well..
Old 09-24-2008 | 01:08 PM
ObsidianIce69's Avatar
yes. What's your question though?
Old 09-27-2008 | 01:26 AM
Maxpwer's Avatar
No turbo, no care!
Curious as to what size water cooling fittings you guys are using? Also where do you guys tap the coolant system for your turbo?
Old 09-28-2008 | 10:29 PM
AceofSpds's Avatar
wat
ive heard of some people using the throttle body coolant lines
dont take me up on that 100% though
Old 09-29-2008 | 02:15 AM
Maxpwer's Avatar
No turbo, no care!
Ok let me clarify, what are the size (ie 16mm, 1/2", etc?) are the coolant threads in your turbo? Further more, Im wondering what type of gasket you used for your turbo coolant fittings? In the past Ive copper and aluminum washers for my banjo bolt fittings, but Ive decided to ditch them for an 18mm to -8AN fitting which came with a rubber o-ring. Do you guys think the O-ring will hold up to the heat of the turbo and if so, would it be any better than the copper or aluminum washers?
Old 09-29-2008 | 03:17 AM
AceofSpds's Avatar
wat
Not sure on most of this stuff, My reply was to the question about where to tap for coolant.
On my 240 i just re-used oem banjofittings from my old t25 and old t28. Not sure about the o-ring either, allot of the SS turbo line kits i have looked at didn't have o rings. Mebey someone else will chime in.
What turbo do you have?
Old 09-30-2008 | 01:43 AM
Maxpwer's Avatar
No turbo, no care!
What type of washers (copper or aluminum) did you use on your banjo fittings? Ive heard that copper (in the case of a head gasket) will leak coolant but I never had a problem with my washers on the turbo. I guess I will ditch the o-ring and stick with the aluminum washers.
I have also heard of people using the TB coolant lines, but since they are less than 9mm and the coolant fittings on my turbo are 18mm, I tapped into the lines that go to the heater core.
My turbo is a large shaft T3 with stage 2 wheels and .82 exhaust housing. (only 440hp capable)
Old 09-30-2008 | 08:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
i'm running AN6 lines. it's getting the feed from the coolant lines after the TB. you don't want to use the turbo to heat up the TB.
the fittings on the turbo depends on size of fitting and what hose size. i think on mine is a pipe thread so some teflon sealant was ok for it.
you can use either copper or alum washers.
Old 10-02-2008 | 05:07 PM
I have AN8 for coolant lines. I didn't tap myself and haven't messed with where it is plumbed into yet to know where.
Old 10-11-2008 | 10:00 PM
wunfstmax's Avatar
I had a gt35r, and used -6 fittings.
Old 10-28-2008 | 08:02 PM
vwracer1172's Avatar
i run a gt35r with -6 lines
Old 11-08-2008 | 07:54 AM
SGT Maxima's Avatar
I used an old fuel pump and windshield washer tank to pump water through the turbo on my 280ZXT. Took some time to get the lines to work right.
Old 11-09-2008 | 06:28 PM
Maxpwer's Avatar
No turbo, no care!
??? This sounds like a good solution, except for the fuel pump with water.......
There is no way you can get a fuel pump to move water; I fried 4 fuel pumps trying to get them to move water. Finally a buddy explained that the putting a fuel pump in water would instantly kill it. I dont remember exactly why, but water + fuel pump = instant dead fuel pump.
Old 11-09-2008 | 11:37 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
get an electric coolant pump from an early mercedes. its a pump that pumps it to the heater core.
in my case i did use the coolant lone that goes to the TB but right after the turbos im using a small cooler to lower the temps which is placed right in front of the radiator.
tarun900
19
12-20-2021 06:57 PM
aw11power
10-10-2021 04:57 AM
Miket2006
03-01-2021 03:55 AM
BobTX10
10-07-2015 08:43 AM
Quick Reply: Anyone with water cooled turbo?
