Another Supercharged 4.5 Gen
Old Oct 25, 2008 | 12:16 AM
mastercater7's Avatar
VQ35 FTW
Well I am in the process of putting the motor back into the car. Anyways the setup is a 2004 VQ35 on 3.0 timing, V2 on a V1 bracket, 2.87 pulley, 3" charge piping, JWT ecu with 370cc and z32 maf, z32 maf, Deatschworks 600cc injectors, Cattman headers, 3" warpspeed catback, Innovate LC-1 wideband, Greddy EMU, ARP rod bolts, and a short shifter. The only problem I have had so far is the the damn injectors and their clips. The injectors are deatschworks 600cc's. For some reason, these clips will not fit snug like the stock injectors do. Someone please tell me the secret!
Thanks,
Zack
Old Oct 25, 2008 | 04:05 AM
JonBlz's Avatar
a.k.a. STuNtMAN
oooh i cant wait to see this in action and see how hard it pulls
Old Oct 25, 2008 | 06:20 AM
Kevlo911's Avatar
Kevlo for President
Are you using Z injector clips, or DEK, or DE?
Old Oct 25, 2008 | 08:32 AM
Snypa's Avatar
this already looks like a beast. Be sure to make videos.
Old Oct 25, 2008 | 08:53 AM
kzoosho's Avatar
I see u went s/c over turbo. Post up wen done. I would love to see it.
Old Oct 25, 2008 | 09:48 AM
VQ35 FTW
I am using the DE injector clips. I believe its the Deatschworks design that makes it difficult to snap these in place. And yes I chose s/c over turbo. A local buddy of mine unfortunately totalled his car and offered me a smokin deal. It should be running today.
Zack
Old Oct 25, 2008 | 10:05 AM
kzoosho's Avatar
Zack
SO you bought the S/C off of Sarins clean white max . Good buy and you better post up some vids man.
Old Oct 25, 2008 | 11:45 AM
ObsidianIce69's Avatar
You're using an emanage and a Jwt ecu?
Old Oct 25, 2008 | 12:32 PM
VQ35 FTW
ya i have had problems tuning and trying to raise the rev limit. this way ill have the raised rev limit and i can tune with the emu
Old Oct 25, 2008 | 07:39 PM
PharoNDmist's Avatar
Nice. I know its going to be a beast. I'm planning on going the same 3.5 S/C route myself soon. I'm searching for build parts as we speak. Please post Videos. Are you going to use some cooling source(intercooler, N02, Meth) of some sort?
Old Oct 25, 2008 | 07:57 PM
VQ35 FTW
In the future. For now I just want it to run.
Old Oct 25, 2008 | 09:00 PM
JonBlz's Avatar
a.k.a. STuNtMAN
pics of it installed and running cant wait
Old Oct 26, 2008 | 02:43 AM
VQ35 FTW
So I have everything hooked up yet the car won't start. The first thing I thought was the fact that there would be too much fuel with the 600cc injectors, thus flooding the motor. I pulled fuel with the EMU and it began to sound mildly different, but still wouldn't start. Next thing I messed with was the Z32 MAF. I tried wiring it differently, and I tried going back to the stock MAF; still no change. A new battery also didn't do the trick. I pulled a spark plug and checked for spark; there is none. Tomorrow I will check fuses. Initially we hooked up jumper cables and I had forgotten to tighten down the main ground. Hopefully I can get this figured out tomorrow. I am way too tired tonight. If anyone has any ideas let me know, same goes for the injector clips (injectors do leak).
Zack
Old Oct 26, 2008 | 06:15 PM
maxgtr2000's Avatar
KH3 by popular demand
Zack, I hope you get it running, but my suspicion would be the ecu since you are not getting spark. For the injector problem, did you use new seals? If so then I would get with Deatschwerks to see if they can figure it out. Hopefully I can ride in this beast soon, but don't kill me man I got kids.
Old Oct 26, 2008 | 06:27 PM
SpeedCrazie's Avatar
Nice work Zack! Sorry I have not got ahold of you about your questions, I have had a bit of misfortune myself with one of my max's and have been trying to figure out what I should do.
Hopefully you get it running right, when you do post vids asap!
JP
Old Oct 27, 2008 | 05:45 AM
Nozama's Avatar
Grumpy old guy
Just a quick update, Zack chased down the spark (bad crank sensor) and then had severe flooding problems. He did a bit more reading and changed the duty cycle on the injectors.
Idle FTW, now it's all about tuning.
Old Oct 27, 2008 | 07:09 AM
liqidvenom's Avatar
brotherhood of tq
damn zack you work fast. what do you drive when the max is down?
Old Oct 27, 2008 | 11:56 AM
dfownz's Avatar
Awesomeness!
How many lbs of boost?
Old Oct 27, 2008 | 12:57 PM
Torgus's Avatar
sick..can't wait to see some #s...
Old Oct 27, 2008 | 01:39 PM
VQ35 FTW
Will, I drove my other maxima haha. And, nozama was close, but it was the lag time mainly, and the fuel psi and duty cycle. I cant seem to get the a/f to go under 12, its staying around 15 so I am pretty scared at the moment. It still has a stock ecu so I am going to try throwing the jim wolf in and changing all the emu stuff to try and get a safe a/f. But wow guys, just resting my foot on the gas, will snap you into your seat. I can tell there is PLENTY of power there, hopefully I can use it soon!
Zack
Old Oct 27, 2008 | 02:02 PM
wirelessdude04's Avatar
cant wait to see the finished project.
Old Oct 27, 2008 | 02:29 PM
mist max2000's Avatar
ohhh im in on this one... im excited
how involved was it going from 3.5 timing to 3.0? is it pretty straight forward or were any (slight or major) modifications needed?
also.. just to make sure.. you have the stock 2004 3.5 cams in there right?
Old Oct 27, 2008 | 02:42 PM
maximase86's Avatar
I love lamp.
Couple things to note Zack, I would verify the MAF wiring when you get the JWT in there. I'm still worried about contention between the EU and the JWT ECU, but now that you've found the ignition and fuel pressure issue, things might be cakework afterwards.
S
Old Oct 27, 2008 | 04:53 PM
VQ35 FTW
Im about to try the JWT ECU here in a bit. It is definitely going to be tricky though. Defownz, I am running a 2.87 pulley which equals 13 psi. Mistmax, they are the 04 cams. I bought a 98 with this motor in it but I totalled it, so I cannot take credit for the full swap. But I did move it over to my gold car which I have had for three years. Pics and vids will be up as soon as I can get it tuned and get the 3" cat back welded up.
Old Oct 27, 2008 | 05:44 PM
Nozama's Avatar
Grumpy old guy
http://forums.maxima.org/supercharge...it-turbos.html
With those 600cc injectors are you running out of flow when you're trying to tune?
Old Oct 27, 2008 | 09:51 PM
maximase86's Avatar
I love lamp.
He doesn't have all the gauges hooked up yet, but we did some runs. So far up around 6k rpm he's dropping down to 9.1afr. The car is pulling pretty good, but there are some clear signs there is a lot of tuning to come. The car bogs down low pretty good, and the power delivery isn't very linear (there seems to be moments of strong pull, then moments of hesitation, then strong pull). The car pulls fast too. We did a 3rd gear pull from 30 and in a couple seconds we hit 80. Right now he's using stock ECU, with Z32 MAF and EU.
The car is going to be ridiculous...reminds me of my car.
Old Oct 27, 2008 | 10:02 PM
JonBlz's Avatar
a.k.a. STuNtMAN
ohhh man another monster on the road
Old Oct 27, 2008 | 10:15 PM
maxgtr2000's Avatar
Since he doesn't have all the gauges hooked up yet, we did some runs. So far up around 6k rpm he's dropping down to 9.1afr. The car is pulling pretty good, but there are some clear signs there is a lot of tuning to come. The car bogs down low pretty good, and the power delivery isn't very linear (there seems to be moments of strong pull, then moments of hesitation, then strong pull). The car pulls fast too. We did a 3rd gear pull from 30 and in a couple seconds we hit 80. Right now he's using stock ECU, with Z32 MAF and EU.
In part that is part of your car !!The soul of the white SE lives on. So guyz, when's the next meet?
Old Oct 27, 2008 | 11:54 PM
VQ35 FTW
I need a tune badly before I want to have a meet. Its been really tempermental and I am tired of ****ing with it. I think I am going to have a shop dyno tune it for me. Then I will get a good tune, and Ill have some numbers.
Zack
Old Oct 28, 2008 | 07:35 AM
liqidvenom's Avatar
brotherhood of tq
just make sure to turn the timing map off in the eu until you get your fuel issue worked out. good luck getting it all ironed out zack.
Old Oct 28, 2008 | 02:15 PM
ajcool2's Avatar
See sig.
Old Oct 28, 2008 | 02:27 PM
oh wow... thanks that looked like a headache.. lol good 4 you..your gunna love that once its running smoother,.. in for the talked about future dyno
Old Oct 28, 2008 | 04:49 PM
VQ35 FTW
The dyno tune is scheduled for thursday at 1. Ill have some results for ya'll on thursday.
Zack
Old Oct 29, 2008 | 12:52 AM
VQ35 FTW
Ok I have some new pictures of it installed. First of all, this was the main reason it wouldn't start.
No splash guards + road debris = unhappy crank sensor. Anyways, on with the happy pictures!
Entire engine bay. The 3.0 piping did not agree with the throttle body position, what a head ache:
I cut a hole in the fender for the cold air:
Old Oct 29, 2008 | 12:55 AM
VQ35 FTW
HKS SSQ blow off valve:
300zx maf and overflow relocated:
Old Oct 29, 2008 | 12:57 AM
VQ35 FTW
Some interior shots, I dont have a boost gauge yet because I am still trying to decide how to hide it, yet see it.
The Innovate LC-1 gauge:
Old Oct 29, 2008 | 12:59 AM
VQ35 FTW
And finally the exterior. I am going for the complete sleeper look, which is also why I want my gauges hidden.
And the only stickers on the car. Gotta rep cattman and the local group!
I hope yall enjoyed these!
Zack
Old Oct 29, 2008 | 06:48 AM
il99max's Avatar
Looks like a nice, clean install. Have fun with it. Hope you have a couple extra sets of tires cause you'll probably burn through those 16's really easy. Can't wait to see the dyno results.
Old Oct 29, 2008 | 08:26 AM
ajcool2's Avatar
The sleeper look is working. Looks nice.
Old Oct 29, 2008 | 12:41 PM
sleeper maxyyy ftwftw
