fuel line hookup?
Old Nov 16, 2008 | 10:13 AM
Cumalot's Avatar
fuel line hookup?
i forgot how the fuel line hookup for the sc install. i know there is a how-to from the sticky, but that was if you used the t-rex fuel pump. what if you will use the walbro fuel pump? how do you route the fuel line with just the vortech fmu? i just totally forgot how things goes. i remembered it was so easy before, i didn't even need to read the direction. please inform, thanks.
this is for a v2 sc install btw.
Old Nov 16, 2008 | 12:36 PM
in tank Walbro===>Fuel Filter ===>Front Fuel Rail/Back Fuel Rail===> OEM FPR===>FMU===>Fuel Return Line.
The top fitting of the FMU is the 'in' port, while the bottom fitting is the 'out' port.
On a side note, don't forget there is always Ptatohed's SC writeup to rely on (found on vqpower.com); it will refresh your memory on a lot of things.
Old Nov 16, 2008 | 06:20 PM
Cumalot's Avatar
yes i know about his writeup, but that writeup is with if you are using the t-rex pump. so the hookup is different.
Old Nov 17, 2008 | 12:00 AM
Incorrect. The hookup is the same. You just wouldn't touch the other fuel line. Read page 9 of 14 of Stillen's instructions and see for yourself.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
