Turbo Specs Help!!
Old Nov 29, 2008 | 09:22 AM
BkGreen97's Avatar
Turbo Specs Help!!
I just bought a turbo with these specs. Got a great deal tell me what you guys think.
Real Original Garrett TO4B 60-1 hybrid turbo with a .70 a/r compressor housing (which can be polished if desired). This turbo is perfect for 4 and 6 cylinder engines looking to pump 300 hp to 500 hp fast (depending on your particular application).
Compressor Housing - Polished .70 A/R, 2.50" inlet and a 2.00" discharge
Cartridge - Standard Journal Bearings System. Oil cooled. 360 degrees thrust bearing
Compressor Wheel - 60mm (2.36'') inducer, 70mm exducer (2.75'')
Exhaust Wheel - Stage 3
Exhaust Housing - Turbonetics T3 A/R .82 On Center, 5 bolt pattern exhaust housing. Fast spooling turbo for high flow engines!
Old Nov 29, 2008 | 09:42 AM
kzoosho's Avatar
Sounds like a 60-1 HiFi which is smaller than the one i have. They are good for tight spots since they are smaller.
Old Nov 29, 2008 | 12:23 PM
BkGreen97's Avatar
I was expecting it to be a bit larger. with a .70 cold side a/r and .81 hot side
Old Nov 29, 2008 | 01:15 PM
kzoosho's Avatar
if it is a true 60-1( there are tons that arent) it will have a better top end than mine.
Old Nov 30, 2008 | 11:41 AM
Ghase's Avatar
It sounds like a good turbo, but what's a 60-1 hifi??? What's the difference between the Garrett T3 60-1 I have (.70a/r cold and .63a/r hot)???
Old Nov 30, 2008 | 01:12 PM
kzoosho's Avatar
The hifi is a more compact version.
Old Nov 30, 2008 | 03:29 PM
BkGreen97's Avatar
Ghase hows your upstairs? turbo wise not having anything to do with your IM. I dont have an 00vi but ill buy a mevi if i have to.
Old Dec 1, 2008 | 07:20 PM
Ghase's Avatar
Topend power is decent, but midrange torque is my cars mojoe..lol And it all starts at 2700rpm and by 3400rpm I have full boost (7-8psi).
She runs good but it will get better when I start doing my own tuning on the Greddy EU.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
