Mastercater7's 4.5 Gen RMT Build Thread
Old Dec 9, 2009 | 09:56 PM
  #41
mastercater7's Avatar
VQ35 FTW
Originally Posted by streetzlegend
Damn i replied but my post didnt go through.
Anyway, the HR bolts have different torque specs which is part reason why they are better, they require more torque in both angle tightening and with the torque wrench. so make 100% sure you get the proper specs, also on that JWT file about the gasket, i think it says the specs, if not look for the specs for the HR 350z or w/e the HR came in, btw you'll notice you have HR bolts because there are TWO dots on the bolt's head instead of 1.
I really doubt anyone makes the same design as the HR gasket, but why would you need stronger? unless your going for over 680WHP, and even then with stronger bolts the HR gasket can probably hold even more power.
Ok yeah the JWT page does have the torque specs, I was just making sure those specs were the same when tightening on a DE head. I was wondering if there was an aftermarket head gasket for the VQ35HR because I plan on having a Nissan that is in the 650-750 whp range in the near future. As for now I have no car to drive and I can't wait to sell the Cometic and buy an HR one, otherwise I would. I am a complete NEWB when it comes to engine internals. Thanks for clarifying.
Conrad, I will take some pics as soon as the bolts arrive. The reason I haven't taken pics yet is because the car and engine is at a friends house. This wait is killing me
Zack
Old Dec 10, 2009 | 12:59 AM
  #42
Nozama's Avatar
Grumpy old guy
Selling the Green Maxima - $2000
Getting all the parts out of the machine shop to put the 3.5 together - $1100
My enjoyment in knowing you have at least another week plus 500 miles before you can kick my *** - priceless
Old Dec 10, 2009 | 01:12 PM
  #43
accordingtou's Avatar
VQ30 DE T
LOL
Old Dec 10, 2009 | 02:21 PM
  #44
VQ35 FTW
LOL its on!
Old Dec 10, 2009 | 02:39 PM
  #45
maximase86's Avatar
I love lamp.
Seeing Chris' car brings back fond memories of Maxine. RIP.
S
Old Dec 10, 2009 | 02:48 PM
  #46
VQ35 FTW
S
+1 on that, she was quite a car.
Old Dec 10, 2009 | 07:35 PM
  #47
505max94se's Avatar
When did you boost your 4th gen?? Do you still live up by running wolf and qfc?
Old Dec 11, 2009 | 06:01 AM
  #48
Nozama's Avatar
Grumpy old guy
I finished the boost but not the tune last weekend and yep still at the same place. Was running a few test flights down 45th last night.
Old Dec 11, 2009 | 10:20 PM
  #49
505max94se's Avatar
We should meet up sometime. I would like to check out your car. I wonder if it's quicker than mine, lol.
Old Dec 12, 2009 | 02:32 PM
  #50
VQ35 FTW
505, I am sure your car is faster now that Noz blew his transmission. So Noz, can you push your car faster than I can push mine? If you can, then yes your enjoyment continues for one week...
Old Dec 12, 2009 | 06:42 PM
  #51
505max94se's Avatar
lol, that sucks. Is it an auto or a manual? How much boost was it making?
Do you need any help with the build?
Old Dec 12, 2009 | 07:22 PM
  #52
Nozama's Avatar
Grumpy old guy
It was an auto that was on it's way out anyways, I can get one cheap and will fill it with synthetic, add a cooler and do the DR mod then I'll be fine. I'll also have a spare to rebuild.
I popped it on a hard launch, the tires spun through first and most of second then grabbed and when I went to a normal cruise first was gone and then I checked and reverse was gone and neutral tries to grab. Toasted..
I was only pushing 10lbs.
Zack, my car is still faster because it starts and drives in second just no boost due to no high revs.
Old Dec 12, 2009 | 08:40 PM
  #53
505max94se's Avatar
Ouch!
If you need any help with your car, let me know. I live just down the street by northshore golf course.
Old Dec 21, 2009 | 10:43 PM
  #54
VQ35 FTW
The bolts finally arrived today. I am hoping to start assembling everything tomorrow but it will most likely be Wednesday or Thursday before I can start. If I can begin tomorrow, I will upload pictures in the morning; otherwise it will be Wednesday or Thursday.
Zack
Old Dec 25, 2009 | 11:42 AM
  #55
VQ35 FTW
I finally was able to get this thing going. The bolts arrived the other day and I almost finished the block yesterday. If I hadn't broke the oil ring on the last piston the block would be done. Anyone know where I can find 1 96mm oil ring? Anyways, on with the pictures!
Old Dec 25, 2009 | 11:45 AM
  #56
VQ35 FTW
Old Dec 25, 2009 | 12:07 PM
  #57
VQ30 DE T
Ok sorry if I missed it but was the block bored decked & honed
Old Dec 25, 2009 | 12:11 PM
  #58
VQ35 FTW
Sorry, no it was not decked. I typed that on accident, it was originally going to be. The shop took way to long and i told them not to because they would have taken much longer. I will get it done when I pull the heads in a few months. The heads were resurfaced
Old Jan 12, 2010 | 02:26 AM
  #59
VQ35 FTW
Well the ring arrived a few days ago and I was able to get started on it again the other night. I made a mistake when assembling the block and had to fix it. Thankfully I caught it, however it made things take longer. I did have to notch my oil pan baffle and I eliminated all but one noise. I can't seem to figure out where it is hitting. Streetz, do you have any pictures of the notched oil pan baffle? I have been a bit nervous since I have never assembled an engine before, but I am confident it will turn out right. Anyways, on with the pictures:
Old Jan 12, 2010 | 02:27 AM
  #60
VQ35 FTW
Old Jan 12, 2010 | 03:11 PM
  #61
VQ30 DE T
I know its not the best way but I used vasaline.. I put a 1/4 dab on each rod bolt & main stud.Then I installed the 3.0 upper pan & rotated the crank until I felt/ heard contact. The vasaline will appear on the baffle(indicating high points) All I did after that was shave/grind down the mounting tabs under the baffle tray. Good luck.
Old Jan 12, 2010 | 03:50 PM
  #62
VQ35 FTW
Thanks for the input accordingtou, I am going to try that in a bit. I am currently installing the timing components.
Old Jan 21, 2010 | 11:17 AM
  #63
ajcool2's Avatar
Update?
Old Jan 26, 2010 | 10:48 PM
  #64
VQ35 FTW
I wasn't able to work on the engine for awhile due to some other issues. Anyways, I fixed the oil pan baffle problem but then I snapped the head off of a bolt on the coolant log. I ended up having to drill a bigger hole because the bolt wouldn't come out. The LIM spacers are on and sealed. You have to use a really small amount of sealant otherwise it squeezes into the injector/air ports and has to be redone. The motor goes in tomorrow and I will post more pictures. I am still trying to decide on spark plugs as well. I remember reading somewhere that you cant use VQ30 spark plugs on a VQ35. However, I read on my350z that a lot of guys are running the VQ30 plugs (based on part #'s) I have to keep researching, but I have 8 brand new NGK 2 steps colder plugs for the VQ30 in my garage. Anyone know about this? On with the pictures.
Old Jan 26, 2010 | 10:49 PM
  #65
VQ35 FTW
Old Jan 27, 2010 | 07:45 AM
  #66
streetzlegend's Avatar
no no on, dont use 3.0 spark plugs. the 3.5 plugs are way longer and you might have trouble getting combustion with the short 3.0, dont experiment like that. them 3.0 plugs were probably only less than 12 bucks, so its not like ur throwing away alot of money. get yourself 1step colder v-power ngk 3.5 plugs and call it a day. (this is the part num, LFR6A-11).
btw, thats the first time iv ever heard of 3.0 spark plugs being used on a turbo/sc setup 3.5, dont do it, dosnt make sense.
Looking good man, cant wait to see your car running. How are you going to go about the break in process, i assume you have new wiseco pistons in there right?
Old Jan 27, 2010 | 03:56 PM
  #67
93altima's Avatar
Turbo 4th Gen
looks good
Old Jan 27, 2010 | 06:48 PM
  #68
maxgtr2000's Avatar
KH3 by popular demand
Streetz, I know, Zack knows, and now you know that this motor will not be broken in properly...
Old Jan 27, 2010 | 10:08 PM
  #69
VQ35 FTW
Here is one of the threads I found where a Z user is talking about the BKR7E-11 series NGK plugs: http://my350z.com/forum/forced-induc...-question.html
Yes new Wiseco pistons, plus all the other new goodies. I am going to do oil changes at 100, 500, and 1,000 miles and then the engine should be done breaking in. I will just adjust throttle and rpms to avoid cruising during the first 1,000 miles. The supercharger will be on there so I will TRY my best to keep my foot out of it
Old Jan 27, 2010 | 11:00 PM
  #70
Yeah thats what I did, I couldnt hold myself. lol. eitherway most say that the best way to break in the engine is to drive it wat it was built for.
as for the plugs, just go with 3.5 plugs man, i would say out of 20 built vq35 guys, only 2 probably have 3.0 plugs (which makes no sense wats so ever), GET 3.5 PLUGS!!!!! one step colder, dont need 2 step, and if you do they actually make them (I have used them before).
Old Jan 27, 2010 | 11:02 PM
  #71
lol, i bet. I dont think babying the car to break it in is the right way either, but who knows what the right way is lol. Iv seen people build a motor and go to the dyno as soon as they started the car.
Old Jan 27, 2010 | 11:38 PM
  #72
VQ35 FTW
I am going to buy the LFR6's, I was just sharing what I found and was curious about this.
Old Jan 28, 2010 | 06:28 AM
  #73
They might have tried using those plugs because there was no 2step colder back then, but I dont think it would be an efficient combustion considering the 3.5 plugs tip is deeper inside the cylinder than the 3.0 plug, so spark blowout might be easy, thats my logic at least. make vids of the car when its done!!!
be safe
Old Jan 31, 2010 | 04:55 PM
  #74
VQ35 FTW
be safe
That's what I was thinking also. I am guessing the threads are different as well, but I definitely know the 3.5l plugs are MUCH longer. I will definitely take some videos when it is done.
Old Feb 2, 2010 | 09:45 AM
  #75
SexyRob's Avatar
good build
  #76
SexyRob's Avatar
oh hey, where did you get those piston rings? I need to order a new set.
Old Feb 3, 2010 | 02:58 AM
  #77
VQ35 FTW
I got them from concept Z. Their website is http://www.conceptzperformance.com
Old Feb 4, 2010 | 08:41 AM
  #78
SexyRob's Avatar
cool thanks!
Old Feb 4, 2010 | 08:42 PM
  #79
VQ35 FTW
Well, some problems have arisen lately (not car related) and I am being forced to sell the supercharger. Atleast I will have a built 3.5; hopefully it will be boosted again very soon. I bumped my previous for sale thread and need to sell it asap.
Zack
Old Apr 28, 2010 | 09:41 PM
  #80
VQ35 FTW
Well, the build is all done and the fun lasted about 700 miles before all the problems started. I drove it around for 500 miles N/A and then put the supercharger back on. The engine is working great and sounds awesome. The car won't start on its own now. When I crank it the engine just floods. I replaced the cam pos sensor and the harness/clip thinking I might have bumped it during the supercharger install but that didn't solve the problem. I also swapped mafs and that wasn't it either. I'm not getting any codes at the moment. When it first wouldn't start the plugs were soaked and I HAD to get the car running so I checked the codes and it threw a cam pos sensor and a maf code. I then compression started it and it ran totally fine. Drove 30 more miles that night without any problems. I am completely lost on what this problem is. The other day I compression started it and it was not happy. When I gave it gas (while barely running) it would try to die, then when I let off the gas it would revup/go back to idle. I am going to check all the maf wiring tomorrow. I am pretty sure it is ignition related but I just can't figure it out. Any help would be greatly appreciated, it has been almost a year since it has ran correctly/ran at all and I need it to run.
Thanks,
Zac
