Oil lines q's
Old Sep 4, 2009 | 10:13 AM
dfownz's Avatar
Oil lines q's
Hey guys,
So I'm about to finally get my car inspected so I can bolt on my TURBO!!!!!! I only need the oil lines and I was wondering how you guys hooked them up.
I have an oil sandwich plate that will have a 1/8npt port for the feed line.
1 - I have a HX35, does anyone know what thread size the inlet/outlet are?
2 - Where do you guys hook up the drain?
3 - Ebay or no?
Any pics of how the drain install goes would be greatly appreciated!
Thanks in advance!
Old Sep 4, 2009 | 12:04 PM
93altima's Avatar
Turbo 4th Gen
in for some pics of some setups too but i was under the impression that it was best to use a brass T from the oil pressure unit that a sandwich plate because the oil filter location has too much oil pressure
Old Sep 4, 2009 | 01:35 PM
nismomaxct's Avatar
I believe you need -4an feed and a -10an drain lines. I hear that you can go with a -3an for the feed and you do not need an oil restrictor if you do. The drain fitting is just your standard t3. The feed fitting is 12.5mm I believe. You can order a 12.5mm to-4an fitting from Summit. It is an Earl's fitting. Hope this helps.
Old Sep 5, 2009 | 02:13 PM
maxgtr2000's Avatar
KH3 by popular demand
Tap the upper oil pan if possible. If not you can get away with tapping the lower one.
Old Sep 6, 2009 | 07:03 AM
dfownz's Avatar
Is there any specific location you guys used for the upper? I'd rather do it right the first time.
Old Sep 10, 2009 | 08:47 PM
s1mply_v's Avatar
^ I want dyno numbers when your done! I finished my S/C setup.
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
doctorpullit
Dec 12, 2015 09:39 AM
