does everyone upgrade to a 300zx maf?
Old Sep 19, 2009 | 03:43 PM
chino86's Avatar
i just upgraded my turbo and my innercooler setup and now when i floor it and i start seeing boost the cars boogs out like symptoms of a bad maf. im thinking im maxing out the stock maf . i was told that i can clamp the stock maf with the emanage boost cut feature but i cant get it to work. i have the greddy pressure sensor hooked up as well. does anyone still have their stock maf? or everyone just upgrades to the n62 300zx maf? my current setup t67 turbo with 555cc injectors and my old setup t04 50 trim turbo with stock injectors both at 8lbs of boost. any suggestions or anyone knows how to get the boost cut feature to work?
Old Sep 19, 2009 | 06:35 PM
maxgtr2000's Avatar
KH3 by popular demand
I'm on the stock maf with the pressure sensor. My car hasn't been professionally tuned so I'm not maxing mine out, the most I've seen was 4 volts. Since you are on a t67 with 555cc you might want to just go and get the z32. I'm only on 370cc with a t3/t4. If you can log on the wideband just see what rpm range you are leaning out and add injection (if you have the greddy injector harness). I clamped the maf once but it started bucking so I don't use it I just add and subtract as needed. You can also log the maf voltage and see where it maxes out also and fix your injection.
Old Sep 19, 2009 | 08:39 PM
streetzlegend's Avatar
Yea, although you CAN continue to use the stock maf, it will make life alot easier if you use a z32 maf. with my 3.0, i had the stock maf maxed out completely, boost was at 15psi. Short answer, yes, upgrade it. I havnt experienced with the boost cut feature, but i know you can completely remove the MAF with the EU.
Old Sep 19, 2009 | 11:16 PM
TurboA32's Avatar
what kind of spark plugs do you have in your car? and if so did you gap them?
Old Sep 20, 2009 | 01:14 PM
You have to gap them depending on the boost. You start reducing the gap once you get spark blowout. Iv always used NGK copper, 2step colder. bkr7es-11 for the 3.0, and for 3.5 havnt memorized it yet lol
Old Sep 20, 2009 | 04:38 PM
chino86's Avatar
i have ngk platinum 1 step colder at stock gap. once i get my car running right then i will regap them
Old Sep 28, 2009 | 08:45 AM
Flava_24/7's Avatar
Boosted Panda
You definately need to gap the plugs accordingly. If your maxing out the MAF you can bet the plugs being at stock gap are also going to be an issue.
Old Sep 29, 2009 | 10:00 AM
This could be the source of your stumbling. ie spark blowout. Regap now, not later. This could fix your issue and you might be able to get by w/o the Z32 MAF.
Old Sep 29, 2009 | 11:07 AM
TurboA32's Avatar
ngk 3.5 plugs one step colder LFR6A-11.
Old Sep 29, 2009 | 11:14 AM
TurboA32's Avatar
and if i were you i would upgrade to the z32 maf anyway. why are you still useing the stock maf?
Old Sep 30, 2009 | 12:49 PM
chino86's Avatar
so i finally got around to regapping my plugs turns out it was spark blowout n my maf maxing out. i gapped the plugs to .032 and took it for a test drive no more hesitation until about 5500 rpm thats where the maf was maxing out and boost was higher than before i'm guessing from the huge pressure drop from the extra intercooler piping. maf maxed out around 14psi, i got the boost cut feature to work dropped the voltage clamp to 4.1 volts and now its running like it should. now i have to worry about traction issues its not grippin for s**t.
Old Oct 10, 2009 | 05:13 PM
didnt follow up on this thread, glad you got the car running properly now. This is on a 3.5 right? We should meet at the track one day.
Old Nov 3, 2009 | 10:46 AM
Redmax's Avatar
Redlinemax Owner
You would also want to change your plugs to copper or iridium as well. If there is plug failure and the tip of the plug breaks off in your motor, the platinum will not burn up and pass through the motor where the copper or iridium will.
Old Nov 3, 2009 | 11:53 AM
I would recommend copper. its the softest out of all, so if for some reason you run into pretty bad detonation or preignition then the plug will most likely melt before more serious engine damage is done.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
