SC setup Blitz BOV -how tight is yours set?
Old Nov 19, 2009 | 02:59 PM
sil SE's Avatar
at the risk of being ridiculed, i'm going to ask this question.
i've read various statments regarding whether being loose will leak boost, and i am also trying to keep a balance so i vent correctly at idle
im seeing about 5psi on a 11lb pulley. that's "whatever" to me since my car has almost 150k and im not looking to destroy it.
so i played with the BOV screw on my BLITZ again and when tightened maybe 3/4 rotation from full tightness, i saw 8lbs.
**i would slip after a certain rpm, perhaps because im on a stock clutch?
does this sound most likely?
but then i noticed i wasnt venting at idle and that is not a wanted effect, (and maybe i was getting psyched out, but my idle was slightly jumpy)
so i loosened it.
**my main question is if you have a BLITZ , do you know about how tight yours is , relative to full tightness or otherwise?
are all the screws identical in these units?
(also i read in one old thread that it was louder facing the bov to the passenger side. anyone have it oriented that way? and is it true? just curious)
thanks all
Old Nov 20, 2009 | 12:18 PM
Flava_24/7's Avatar
Boosted Panda
so i loosened it.
thanks all
I ran the Blitz with a 3.0 pulley and never had issues with it. I cant remember just where it was set at, but I know it wasnt tightened all the way down. When your adjusting it, are you loosening the nut and then raising/lowering the threaded post? What pulley are you on?
Where is the boost gauge recieving vac from?
Old Nov 21, 2009 | 09:00 AM
sil SE's Avatar
Thanks dude. I'll check my plumbing (it was installed by pro and I haven't really gotten around to examining the source of the boost pressure reading)
Its a 3.125 pulley and I adjust the screw by first loosening the nut.
Where's the most accurate source to tap line for the boost gauge? (Its a prosport gauge which I've had luck w before)
Old Nov 26, 2009 | 02:12 PM
sil SE's Avatar
i think my boost vac line is tapped to a source that is plugged into a stock nipple protruding from i guess the lead into the intake plenum right after the TB
does that sound right to you?
i adjusted the BOV to vent generously during idle, but just before its too tight to not do so. i guess thats balanced.
so unless someone can verify that the vac source for the boost gauge is correctly tapped, maybe im reading a faulty boost reading?
Old Nov 27, 2009 | 08:54 AM
Flava_24/7's Avatar
Boosted Panda
That should be ok, just as long as there arent too many other things also on that source.
Old Nov 30, 2009 | 08:07 AM
sil SE's Avatar
iirc from what I saw the other day, it is T'ed one more time (downstream to the gauge) to plumbback (?) line from the BOV.
thanks for the insight flava
Old Feb 21, 2010 | 08:27 AM
brasso's Avatar
I have the blitz bov. I cant get it to vent at idle no mater how much i loosen it . any idea why?
Old Jan 28, 2012 | 07:48 PM
Quickywd01's Avatar
Take it off, open it up and oil everything up. That worked for me.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
BkGreen97
Apr 2, 2016 05:47 AM
alphakaoz
Sep 30, 2015 07:33 PM
Bonka
Sep 14, 2015 11:18 PM
