Supercharging a 5th gen
Old Feb 7, 2010 | 10:46 AM
maxima1239's Avatar
I have some questions on supercharging a 5th gen. Can i just use the 4th gen charge piping on a 2000 maxima. I've read something about the maf being on the charge side and it will not work but I'am confused because they both have the same engine bascally. Mainly do i have to buy a 5th gen charge pipe or can I get away with the 4th gen piping i already have. Thanks guys, trying to get my 5th gen boosted. I was planning on boosting my 1998 maxima but I sold that and bought a 2000 maxima.
Old Feb 7, 2010 | 01:30 PM
Quickywd01's Avatar
You can get away with using the 4th gen piping.
A 4th gen setup has the maf on the boosted side, therefore air goes through a filter and into the sc then through the charge pipe through the maf and into the engine.
A 5th gen setup has the maf before the boost so air goes through a filter and into the maf then to the sc and into the engine.
What other parts do you have? What sc v1 or v2? What size pulley? Fuel pump? Spark plugs? Are you going to use a FMU?
Old Feb 7, 2010 | 01:41 PM
nismomaxct's Avatar
secondtonone17 had 4th gen piping on his 5th gen. Search through some of his threads to get an idea of what you need to do. I think you are going need a few extra bends in addition to the piping because the throttle bodies are in a different location on the 4th and 5th gen.
Old Feb 7, 2010 | 04:18 PM
maxima1239's Avatar
I have v1 blower with a v2 plate. I don't have an fmu or any fuel pump because I'am only going to be running 7psi and I don't think i would need to upgrade my fuel management. Would i need to? I have ngk copper spark plugs but haven't gapped them yet. For now I want to run 7psi so i can learn everything at first then upgrade my fuel management and run a bigger pulley.
This is the kit I bought:
http://forums.maxima.org/forced-indu...cessories.html
Old Feb 7, 2010 | 04:30 PM
Mr.A32ftw's Avatar
fixed
Old Feb 7, 2010 | 07:53 PM
maxima1239's Avatar
Originally Posted by mariosmax
fixed
oh my god, didn't even mean to do that.
Old Feb 9, 2010 | 10:15 AM
Quickywd01's Avatar
Get a FMU or larger injectors. Says 2 fuel pumps so that should be ok but you should get a FMU. Did you buy everything in that FS thread?
Old Feb 9, 2010 | 01:06 PM
93altima's Avatar
Turbo 4th Gen
youll need a aux pump and fmu and your in luck:
http://forums.maxima.org/forced-indu...it-gauges.html
Old Feb 9, 2010 | 05:48 PM
maxima1239's Avatar
Bought everything in the kit except the gauges
Old Feb 9, 2010 | 06:47 PM
maxima1239's Avatar
Can I wire a 4th gen maf without any problems?
Old Feb 14, 2010 | 12:20 PM
Quickywd01's Avatar
In the FS thread it says "2 Fuel Pumps" but you are right he still needs a FMU.
Old Feb 17, 2010 | 07:25 PM
maximal01's Avatar
good buy, i woulda went with the gauges just so i didnt have to hunt for them but 400 for just gauges is kinda pricey but good buy
Old May 19, 2010 | 03:54 PM
maxima1239's Avatar
So I'm boosted now and running on all stock fuel pressure. I have a t-trex fuel pump that comes with the stillen kit but have not put that in. I have a 3.6 pulley and im hitting like about 6lbs. Would that fuel pump be enough and would I need a FMU? If yes which disk? And to clear things this is on a 2000 dek maxima. Thanks guys im just worried to boost it now because i dont want to run lean. The person who i bought the kit from said i should be okay with stock fuel management.
Old May 19, 2010 | 04:50 PM
Rood's Avatar
wideband. now.
Old May 19, 2010 | 05:33 PM
93altima's Avatar
Turbo 4th Gen
you should atleast have a fmu but like mrood said you NEED a wideband
Old May 20, 2010 | 02:45 PM
maxima1239's Avatar
What ratio or disk vortech fmu would i need for the setup i have?
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Violator
Sep 9, 2015 10:14 AM
