Budget build
Old Apr 27, 2010 | 09:47 PM
  #41
streetzlegend's Avatar
Nothing wrong with ebay couplers as long as they are silicone and at LEAST have one layer on them, I have never had any issues with couplers, even at 20psi. Actually to be honest, half of my couplers were radiator hoses lol, has worked for 3 years though lol. The rest, silicone with at least 1 layer, cheap ebay ones.
Old Apr 28, 2010 | 05:50 PM
  #42
bryan163's Avatar
Originally Posted by krazy6
Nice! Then you are obligated to post a video of you ripping on it.
yes, a video would be nice. Make sure your blow-off valve is opening. the pressure might be spiking when you close the throttle body and popping the couplers. I had to tighten the hell out of all my T-bolt clamps because the couplers would pop off when I would shift gears. I never did have one rip even at 16psi though.
Old Apr 28, 2010 | 07:23 PM
  #43
93altima's Avatar
Turbo 4th Gen
Vid will come once i stall my injectors
Old May 1, 2010 | 08:06 PM
  #44
93altima's Avatar
Turbo 4th Gen
fixed all the oil leaks and i re-routed the oil drain hose and i put wire loom over it, iam also picking up my 550s tomorrow and ill prob install them also. Besides that iam still waiting for my new 90degree couplers to come in
Old May 1, 2010 | 11:01 PM
  #45
Man speaking of blowing couplers today i had a scare, was doing some tuning at 15psi, once I left off BAM!, pipe came off the TB, note to self: never use electrical tape to make a pipe thicker lol.
Old May 1, 2010 | 11:43 PM
  #46
93altima's Avatar
Turbo 4th Gen
use speaker wire
Old May 2, 2010 | 12:40 AM
  #47
Originally Posted by 93altima
use speaker wire
Thought of that, but then got paranoid of what if it flew inside somehow lol.
Old May 2, 2010 | 03:46 AM
  #48
KRRZ350's Avatar
Nice.
What did you use for a fitting for the return line in the steel pan?
Old May 2, 2010 | 08:44 AM
  #49
93altima's Avatar
Turbo 4th Gen
That would suck BIG TIME
Originally Posted by KRRZ350
Nice.
i use a 3/4th heater Hose fitting
Old May 2, 2010 | 09:48 AM
  #50
maxgtr2000's Avatar
KH3 by popular demand
The guy that fabricated my setup got a long piece of 3 ply and just cut them to fit, the only piece that has a "degree" of bend is coming off the turbo going to the intercooler piping. All the other bends are welded.
Old May 2, 2010 | 01:01 PM
  #51
93altima's Avatar
Turbo 4th Gen
iam gonna eventually get some of the welded together but not at the moment
Old May 2, 2010 | 01:02 PM
  #52
93altima's Avatar
Turbo 4th Gen
Well i just got back from getting my RC550cc Injectors, so now all i have to do is order 6 injector spacers, any 1 got the part numbers for them??
Old May 2, 2010 | 04:14 PM
  #53
KRRZ350's Avatar
Word, I've used those in the aluminum pans before but was nervous doing it in the thin steel. Just drilled & tapped correct? I was originally planning to see if a radiator shop could somehow braze it.
Old May 2, 2010 | 04:43 PM
  #54
93altima's Avatar
Turbo 4th Gen
drilled and tapped and jb welded
Old May 2, 2010 | 05:00 PM
  #55
93altima's Avatar
Turbo 4th Gen
Took moff the Intake mani's to Install the Injectors
pics:
Old May 2, 2010 | 05:01 PM
  #56
93altima's Avatar
Turbo 4th Gen
Rc's w/ plug and play injectors
Clips Installed:
Old May 2, 2010 | 05:03 PM
  #57
93altima's Avatar
Turbo 4th Gen
Off topic:
My Boys Holset Powered Ka-T S13
Old May 3, 2010 | 04:51 AM
  #58
JAMAICANLOVRBOY's Avatar
So no more fuel issues, let's fire it up
Old May 3, 2010 | 06:39 AM
  #59
93altima's Avatar
Turbo 4th Gen
still waiting on the couplers
Old May 3, 2010 | 10:42 AM
  #60
lol i see you using the 7m supra's trunk for storage
Old May 3, 2010 | 10:46 PM
  #61
93altima's Avatar
Turbo 4th Gen
lol
Old May 3, 2010 | 10:51 PM
  #62
93altima's Avatar
Turbo 4th Gen
Well its 1:46am and i just got back from test driving the car.....I installed the Injectors LIM and UIM at 12:00am and drove around Open Downpipe, iam the type of neighbor you would hate lol
Well iam trying to figure out what psi to set my fpr at it was leaning out at 20,30 then i raised it to 40 and it was running super rich and it would start to break up while going into boost. So in the morning (or daylight i should say) iam going to lower the psi to 35 at WOT and see hoe she acts but boost is very addicting lol
Old May 4, 2010 | 12:53 AM
  #63
krazy6's Avatar
In for the vid now that you got it running!
Old May 4, 2010 | 02:38 AM
  #64
Vegas_s12's Avatar
Damn that's a nice sleeper for sure how much power you looking to get
Old May 4, 2010 | 03:58 AM
  #65
t6378tp's Avatar
Turbo 3.5
Try without the vac hooked up to the afpr
Old May 4, 2010 | 08:29 AM
  #66
93altima's Avatar
Turbo 4th Gen
Video coming Real soon
Thanks, and around 350-400whp
Yea thats how i was setting it.
Well i Set the fpr to 35psi, and lowered the corrections on the afc to -20 and under boost iam seeing 11.0-11.6 under boost!!!
But Since iam on local roads iam yet to go WOT and i cant tell how much Psi the wastegate is at, i did a little pull and i seen it go up to 10psi but its hard to get aa real reading because i loose traction as soon as the turbo goes over 4psi and it tq steers to the right. So tonight Iam gonna do some street tuning on the h.way when theres really no one on the road to get in my way
Old May 4, 2010 | 10:57 AM
  #67
93altima's Avatar
Turbo 4th Gen
Well i went for another ride (i cant help it) and i did a 3rd Gear pull and i seen 10lbs and it spiked up to 15lbs and came back down to 10lbs, so iam going to install my Boost controller to keep it around 10-11lbs.
Old May 4, 2010 | 10:58 AM
  #68
krazy6's Avatar
Sounds like you are getting really close to having this thing 100%
Can't wait to see it run, gonna be fast!
Old May 4, 2010 | 01:03 PM
  #69
93altima's Avatar
Turbo 4th Gen
i got you with a video this weekend
Old May 4, 2010 | 01:05 PM
  #70
93altima's Avatar
Turbo 4th Gen
well i insatlled a new fitting for the oil feed line into the turbo( The old 1 had a leak) and i installed a .041 Oil resrcitor
I want to thank kelvo and streetlegendz for the info on that part
Old May 4, 2010 | 04:17 PM
  #71
maxgtr2000's Avatar
It would be wise to look into some timing control if you plan to be consistently in double digits especially with the afc bumping up the timing (-20 correction). I had an 8lb spring that spiked to 13 so I got rid of that and got a 5lb spring and use a boost controller with it to keep my boost around 8-10lbs. I used to think a 10lb spring would keep me no more than 10 but it cracks at 7lbs. Other than that boost doesn't continue up as fast but it can still continue up.
Old May 4, 2010 | 06:52 PM
  #72
93altima's Avatar
Turbo 4th Gen
Yea me and a local member was actually talking about this so i lowered the fpr to 30psi @WOT so i can add fuel instead of pulling fuel
Old May 4, 2010 | 06:53 PM
  #73
t6378tp's Avatar
Turbo 3.5
^ yeah I told him that earlier
LOL, we must have been typing at the sametime
Old May 4, 2010 | 08:12 PM
  #74
93altima's Avatar
Turbo 4th Gen
Well Well Well...2 words Possible Partout!! dont ask
Old May 4, 2010 | 08:21 PM
  #75
Flava_24/7's Avatar
Boosted Panda
WHAT THE??
never saw this coming, sorry to hear man.
Old May 4, 2010 | 08:28 PM
  #76
93altima's Avatar
Turbo 4th Gen
Originally Posted by Flava_24/7
WHAT THE??
**** happens, Some more than others
Old May 4, 2010 | 09:03 PM
  #77
Blew?
Old May 4, 2010 | 09:16 PM
  #78
93altima's Avatar
Turbo 4th Gen
Blew?
not necessarily
Old May 4, 2010 | 09:41 PM
  #79
krazy6's Avatar
What happened? We were just getting to the good stuff.
Old May 4, 2010 | 09:56 PM
  #80
lilconfused's Avatar
nicee i really need to get workiin on mine llo
