My s/c pulley is coming loose again...whats the fix?
Old May 5, 2010 | 07:30 PM
MaximaSpd85's Avatar
hey, i had this issue the first week that my pulley seemed that it was sliding off and rubbing the bolts held captive. it was installer error, i didnt have the washer(s) on the pulley correct and the pulley had play. so i fixed that, and put blue tocktite on it. tightened as tight as i could. 2 weeks later, tonight i see that its doing it again. im assuming it has just occurred within the last day or so. luckily, i was planning on swapping to the 2.87 pulley tomorrow anyways, so it was just on time. but what can i do to prevent this again?
how permanent is red locktite? how is the original setup supposed to look? i have the pulley, then a thick looking washer, and then the stock hex cap screw. ive since added more washers cuz there was play (my issue the first time). any other routes i can take? ive seen some with just regular hex head bolts...or am i just tightening it like a sissy?
Old May 5, 2010 | 08:28 PM
PFI30t's Avatar
you can get the stock one which will solve your issues as i told you before i have some spare bolt also you can get pulley key and a new or used pulley and the bolt is a hex set up from stillen
http://www.vortechsuperchargers.com/...on.php?pvk=417
Old May 6, 2010 | 07:29 PM
matty's Avatar
I wouldnt use red
How are you holding your pulley while tightening the bolt ? I use a rubber Oil Change wrench on the pulley, and then tighten the bolt. I never had an issue with that coming loose
-matt
Old May 6, 2010 | 08:51 PM
Originally Posted by matty
I wouldnt use red
Agreed.
That's the first question that came to my mind as well.
Old May 6, 2010 | 09:22 PM
96sleepergle's Avatar
I wouldnt use red
-matt
Yep thats the proper way to do it also get the proper pulley washer so you dont have the same problem proping up, When i was supercharged had the same problem until i replace the washer, used the rubber strap oil filter changer wrench to tighten the pulley.
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
02PearlSE
Oct 7, 2015 02:12 AM
kenc15
Sep 25, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
