turbo ???
Old Sep 4, 2010 | 04:04 PM
turbok2x's Avatar
turbo ???
hey guys, i was just about to start making my reverse y-pipe for my turbo but i couldnt decide what piping size to go with...what size did you go with from bank 1 and bank 2 to the collector then to the turbo?? i will probably go with a t3/t4 turbo...not to sure what brand....also what size intercooler piping to go with?? i see some people run 2.5'' and some run 3''...what whould you suggest???
my set is (parts that i already have):
stock internals vq30de in a 95 fed spec maxima 5 speed
mevi intake manifold
act 6 puck clutch
definitive crank pulley
greddy emanage ultimate
ngk wideband
tial 38mm wastegate
tial 50mm bov
still looking for a turbo, and a intercooler and piping...
debating on if i need head studs or not
my goals will be the most whp i can make with a stock vq30 without blowing the motor...
anything i need to upgrade or anything that you would suggest??
lmk
thanks
Old Sep 4, 2010 | 11:07 PM
Nealoc187's Avatar
SLOW
You left injectors off your list of things you still need. You WILL require injectors for this. I would also HIGHLY recommend a reliable methanol injection setup. If you want to push the limits, it is one of the most effective ways to keep your motor together.
Anyways, IC piping - 2.5 is more than sufficient for 450whp which is about as high as you're probably going to want to push a VQ30 (and 450whp will require a tune that is on the money).
Forget reverse Y. Reverse Y setups are old school. Extra piping means more lag, worse performance, and more weight. Do a forward Y. It's pretty well mapped out how to fit a Forward Y these days.
Forget a UDP. UDPs are a complete liability and provide virtually zero gain. 1-2hp at most, and that 1-2 hp comes at the risk of ruining your engine, an engine which you have already stated you want to push to it's limit. You'd be absolutely out of your mind to put a UDP on this setup.
What turbo you get depends on a lot of factors, need more info on your intended use of the car and what your requirements are as far as lag and response goes, etc. Also your budget and personal preferences.
Personally, I'd probably get a Master Power brand turbo if I were buying a brand new these days. You can also piece together a good turbo if you're willing to search out individual parts or have one rebuilt for a few hundred bucks. Lastly there's always Holsets.
Old Sep 5, 2010 | 12:29 PM
turbok2x's Avatar
what size injectors would you reccomend me getting and what brand?
meth injection: whats good? brand? never ran meth injection before
ic piping: perfect...i have univesal 2.5'' piping i bought from ebay years ago...i can finally put it to good use
reverse y-pipe: i meant foward facing y-pipe
udp's: ok...its coming off
turbo: dont know what size...my intended use for the car is to make the most power with a 3.0l...i want to hit 500whp but i dont know if the rods can handle that much...i dont know if i should get rod bolts and head studs to make it more reliable...should i??? car will be a daily driver...i plan to set rev limit to 7k rpm if thats not to high...i want to shift from gear to gear without droping out of full boost...any specific size you would reccomend??
Old Sep 5, 2010 | 01:06 PM
maxgtr2000's Avatar
KH3 by popular demand
http://forums.maxima.org/7701223-post3.html
Old Sep 15, 2010 | 07:30 AM
witeonblakmax's Avatar
you wanna buy a kit?
Old Sep 17, 2010 | 04:12 AM
turbok2x's Avatar
nope
Old Sep 17, 2010 | 08:29 AM
InfinitiI35Rice's Avatar
Im planning on doing a kit for a I35 and thinking about running it from my y-pipe too. I heard if you wrap and insulate it keeps lag to the least.
Old Sep 17, 2010 | 02:43 PM
idk about that turbo lag comment. I guess in theory it would probably help the lag issue but with my setup i dont think i would have to worry about lag much.. I start spooling at 1500rpms. full boost at like 22-2500
Old Sep 17, 2010 | 02:58 PM
t6378tp's Avatar
Turbo 3.5
And he does all this with a nice size turbo. On a VQ3.5 this kit would start boosting at idle.
The piping on this kit is shorter than some four bangers
Old Sep 17, 2010 | 03:31 PM
tibal's Avatar
http://forums.maxima.org/forced-indu...-part-out.html if you looking for any parts, i got most from people on here!
Old Sep 17, 2010 | 06:04 PM
lol the funny thing is your probably right because 1500 is pretty damn close to idle.. As for the OP, 500whp is too high of a goal. Wait and get the car boosted first then possibly add meth later but not right away. Also figure out what size turbo you want to run. Put it this way, a garrett gt30 would be too small for the motor. A gt35 is a good starting point
Old Sep 30, 2010 | 01:35 PM
nissanfreak6465's Avatar
sorry people but i have to ask a one of the stupid question where is turbo housing connected to on the exhaust side or intake side
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
