Need help w/Greddy EU *ASAP*
Old 11-10-2010, 05:57 PM
furbiss112's Avatar
Well, I had the car running but know it won't start. Here is the set up.
Z32 maf
stock injectors
walbro in tank
stock fuel pressure regulator
patherfinder TB
turbocharged
I got few things re-done on the car so I can finally go in for some tuning. Now it won't start. Seems like I am getting too much fuel. Tried to pull fuel but no go. If any one has a map that is close to this to help me get my car started please email it to. I am supposed to go for tuning on Saturday. I spent most of the day today trying and nothing worked.
I did notice that the RPM on the car and EU won't go passed 400 ish while cranking and vacum gauge stayed ar 0. Do not know if that is normal.
Contact info:
ferhan_syed1@yahoo.com
847-220-3841
Thanks in adance guys.
Ferhan
furbiss112 is offline
Old 11-10-2010, 07:40 PM
VQ35 FTW
mastercater7's Avatar
What were the few things you did to the car? What injectors are you running?
mastercater7 is offline
Old 11-10-2010, 08:42 PM
furbiss112's Avatar
Added pathfinder TB, fixed coolant lines, and installed built transmission. When back to stock injectors tune to break in engine and make tuning easier for now.
Ferhan
Old 11-11-2010, 01:29 PM
VQ35 FTW
If you put stock injectors back into the motor, then the EU settings have to be changed back to stock.
Old 11-11-2010, 01:33 PM
furbiss112's Avatar
I have nothing changed in the EU maps. I have injectors at 270cc for before and after. It just won't start. It cranks over but it won't fire up.
Ferhan
Old 11-11-2010, 01:35 PM
VQ35 FTW
What engine?
Old 11-11-2010, 01:41 PM
furbiss112's Avatar
Vq30de stroked to 3.2/3.3 ish.
Ferhan
Old 11-11-2010, 01:43 PM
VQ35 FTW
I thought the VQ30 injectors were smaller than 270??? Maybe I am wrong, but if I am I would check for vacuum leaks, just go back over everything you did. The problem has to involve something you messed with if it isn't injectors.
Old 11-11-2010, 01:55 PM
furbiss112's Avatar
I have check all vacum lines, checked all sensors too just to be sure. I though the injectors were 230cc but everyone else told me 270cc.
Ferhan
Old 11-11-2010, 02:16 PM
KH3 by popular demand
maxgtr2000's Avatar
Is your cam sensor good/plugged in? It will crank but won't start.
maxgtr2000 is offline
Old 11-11-2010, 03:47 PM
furbiss112's Avatar
I checked that too. It its not an OEM but it is the Hitachi that was within spec.
Ferhan
Old 11-11-2010, 03:53 PM
MoncefA33's Avatar
Are your parameter & jumper settings on the EU correct?
MoncefA33 is offline
Old 11-11-2010, 03:57 PM
furbiss112's Avatar
Yes they are since it was running on the EU before.
Ferhan
Old 11-12-2010, 07:50 PM
streetzlegend's Avatar
Redo the grounds to EU. Also start a new file from scratch. Those are two things i did wen i had similar issue, and worked
streetzlegend is offline
Old 11-12-2010, 07:56 PM
MaximaSpd85's Avatar
you forgot to sand down the mating surface between the engine and tranny...?
MaximaSpd85 is offline
Old 11-14-2010, 05:33 PM
JeEvE's Avatar
I had a similar starting issue because of this, I just ran a separate ground wire to the trans. Mine would sometimes start up after some cranking but if it was warmed up, it was a no go.
JeEvE is offline
Old 11-15-2010, 01:12 PM
furbiss112's Avatar
Well, tested afew more things and it turns out the stock ecu is toast. It will not fire cylinder 2 and 5 coils at all. I will be switching out the 97 ecu with a 96 ecu I have at home. Hopefully that should solve the problem.
Ferhan
Old 11-16-2010, 08:40 AM
Ferhan
What do you think may have caused this?
Old 11-16-2010, 09:13 AM
furbiss112's Avatar
I have no idea. I was having fuses blowing out before this too.
Ferhan
Old 11-16-2010, 02:58 PM
VQ35 FTW
Did you tap your EMU power off of your ECU power?
Old 11-17-2010, 05:33 AM
furbiss112's Avatar
The EU is wired using DandyMax's write up. I will see what happen this Saturday when I switch the ecu.
Ferhan
maxfever1987
11-19-2016 08:01 PM
NewMax03
10-29-2015 07:44 PM
MaximaRaj
27
10-02-2015 07:31 AM
zzznightmarezz
09-21-2015 06:32 PM
chernandez1278
09-16-2015 01:18 PM
Quick Reply: Need help w/Greddy EU *ASAP*
