Anyone with EMU and 600cc injectors, step inside!
Old Jun 4, 2011 | 06:43 PM
OC_Nooby's Avatar
Hey guys,
Long story short I keep flooding my car using the Emanage Ultimate and 600cc injectors tuning via duration. If i use my original tune with duty cycle the car does not flood.
Setup:
Emanage ultimate
Detchwerks 600cc injectors
Walbro 255
So anyone who is tuning via duration with 600cc injectors can you tell me the following.
Do you scale your injectors? If so whats the before/after CC and Lag times?
Do you have a FPR and O2's plugged in? or do you just have fuel pump to injectors?
I'm trying to figure out why I can't tune via duration without the car flooding but tune via duty cycle and have it start every time. I've tried everything I could. This **** don't make any sense. Also once the car is started in duration my idle is all over the place, I can't get it stable. In duty cycle the idle is very stable with just an 00VI IACV connected.
Old Jun 5, 2011 | 11:30 PM
Unklejoe's Avatar
Originally Posted by OC_Nooby
Hey guys,
Setup:
Emanage ultimate
Walbro 255
I have the exact same problem.
My solution was...
tune using duty cycle.
Sorry, but this is no help.
Every time I would try and use duration, my car would flood out and it would not start again.
I even tried with all the maps zeroed out.
Is there a reason you don't want to use duty cycle?
Old Jun 6, 2011 | 06:53 AM
OC_Nooby's Avatar
My solution was...
you can't extend the redline using duty cycle.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
