Head gasket replacement???
Old Jul 21, 2011 | 05:57 PM
2maxximum's Avatar
I've looked around trying to see what every one else is using. I have a turbo maxima and my head gasket is bad, what is the best head gasket for a turbo maxima? I've upgraded my pistons, rods, and cams. I had a metal head gasket thinking it would hold guess I was wrong need something better.
any help will be appreciated...
Old Jul 21, 2011 | 08:11 PM
streetzlegend's Avatar
its not only about the head gasket, its the head bolts you use! Get same gasket but get some heavy duty bolts. like L19
Old Jul 22, 2011 | 06:06 AM
Kevlo911's Avatar
Kevlo for President
VQ30/35 gaskets are interchangeable so you will find a bunch for 350zs that you can use. You might have to mod the cooling passages but nothing big(although this might only be for the HR gaskets)
Old Jul 22, 2011 | 05:09 PM
2maxximum's Avatar
that makes alot of sense .... because it only does it when I drive it really hard. hmmm. thanks for the help every one. and a 350z hr gasket can be used I will look for that right up thanks again every one.
melteye
May 16, 2016 12:02 AM
ac max 92
Sep 2, 2015 04:23 PM
FlaMark
25
Aug 28, 2015 10:15 AM
Samedi
Aug 12, 2015 01:54 AM
acw
Aug 7, 2015 04:20 PM
