Possible part out....
Old Apr 10, 2012 | 02:14 PM
  #81
McSteve's Avatar
well it probably happened because timing skipped. The only way to see whether timing is really messed up if you turn it over until it goes to cylinder 1 TDC and see what the timing is then.
Valve lifter clearance is also a think he should have checked.
and that picture does look misaligned.
Old Apr 10, 2012 | 02:43 PM
  #82
t6378tp's Avatar
Turbo 3.5
Originally Posted by Flava_24/7
So in your opinion, you think he didnt pressurize the timing tensioners resulting in the thrown off timing?
Also, should this be like this? Seems like it should be centered more...
that is not correct
Old Apr 11, 2012 | 08:05 AM
  #83
meximax's Avatar
SC Overspinning Swapper!!
Originally Posted by t6378tp
that is not correct
I disagree, that perceived misalignment is normal. There is no adjustment in the alignment of the hydraulic tensioner or actual chain slider. Neither of those components have sloping slots at their fastening points. Its look "off" because the plunger isn't extended. Under pressure, that plunger will stick out about 1" and both plunger and chain guide seat (which moves outs) should be very close to concentric.
BUT, what doesn't look right is the fact that the plunger is almost fully "in" without having a pin (paper clip, pushpin, etc.) that goes in that little hole. That tensioner has a beefy spring that helps keep tension during no-oil conditions (i.e. startup). I recall always having trouble introducing a pin that hole due to that spring. If you remove it, that plunger should jump out. If it doesn't, then that tensionser could be bad, and potentially the culprit for a skipped tooth.
My $.02
Old Apr 11, 2012 | 08:12 AM
  #84
meximax's Avatar
BTW, don't remove any of the timing equipment until you have confirmed that you have skipped tooth. You will have to rotate the crank more than a few times to get everything to align. The crank is easier to turn when you don't have spark plugs and when the throttle body is open.
Old Apr 11, 2012 | 10:12 AM
  #85
t6378tp's Avatar
Turbo 3.5
All that to say the way it appears in the pic is not the way it should be
Old Apr 11, 2012 | 11:45 AM
  #86
Flava_24/7's Avatar
Boosted Panda
I havent removed any of the timing components yet, the top end is all removed so it shouldnt be too hard to turn over to get everything lined up.
Thanks for the input, its greatly appreciated!
Old Apr 11, 2012 | 12:52 PM
  #87
taz394's Avatar
That's insane. At least your license plate has meaning now.
LOL you funny ... in a dumb way ... but i like that LOL
Originally Posted by McSteve
has to be timing right? i don't think i've ever heard of a cracked valve on a vq before.
That's what I was thinking, either that or the lash was set incorrectly? I've never heard of this happening in a VQ either, nor have I ever heard of a valve making its way all the way through the exhaust.
*raises hand*
i actually cracked mine last year at the track at IFO
but thats after thousands of miles of spraying the **** out of it and abuse 5 nights a week
seems odd though ... def the guy that built it screwed something up
i wouldn't part it out ... you have a nice little panda there ... buy a new motor and slap it in
Old Apr 11, 2012 | 12:53 PM
  #88
meximax's Avatar
Apparently my long winded explanation still wasn't enough since you still didn't understand that the concentric misalignment in the picture "IS" the way its should be in that state of operation.
Your comment of "that is not correct" does nothing for the OP. Next time you feel like giving an opinion, at least back it up with a methodical and logical explanation for the perceived mechanical anomaly.
Old Apr 11, 2012 | 05:32 PM
  #89
t6378tp's Avatar
Turbo 3.5
Mmmmmm no
Old Apr 13, 2012 | 04:13 PM
  #90
Quickywd01's Avatar
This is getting good.
Old Apr 18, 2012 | 07:53 AM
  #91
Flava_24/7's Avatar
Boosted Panda
A bit of an update.
We checked the timing, everything lined up and the cams were in the correct position so it doesnt appear to be the issue.
Pulled the heads and WOW.
Right now, it could've been due to two different things. Either the valve clearance wasnt correct for that one piston resulting in the valve smacking the pistion until it bent, then puncturing the piston and then finishing off the valves or the valve could have simply broke and the fragments destroyed everything else.
Right now the damage is to that piston, head, and one of the exhaust cams. Looks like when the valve hit the pistion it jarred the cam assembly upward causing it to smack the shim against the cam lobe and bending the shim, and the upward force destroyed the end of the camshaft. So what I previously thought was a piece of a broken cam adapter was actually the end of the camshaft.
THE CARNAGE:
But on another note, I had this come in the other day,...
Its got just under 50k, So the plan is for the Panda to be around for a bit longer.
Old Apr 18, 2012 | 07:58 AM
  #92
Crusher103's Avatar
jesus, yea that was cam install issues, that looks terrible.
Old Apr 18, 2012 | 08:27 AM
  #93
meximax's Avatar
Wow. That is true carnage. Glad to see that there is another VQ on deck.
Old Apr 18, 2012 | 10:48 AM
  #94
McSteve's Avatar
@Flava
man you should take some more artsy pics or photoshop those pics a little and those would be frame worthy. Don't think i came across damage like this on the forum yet.
Good luck with your new engine build! Get the rev ups with properly specd adapters too bad you didn't wanna do the 3.5 swap!
Old Apr 18, 2012 | 11:51 AM
  #95
Flava_24/7's Avatar
Boosted Panda
@Flava
Cash is very short for me right now, so I dont forsee me purchasing another set of Rev Up cams and adpaters.
The donor motor will get the HR valve springs and HR headbolts and due to all the metal I found in the pan I purchased another 3.5 oil pump. Actually went with the Rev Up pump.
Old Apr 18, 2012 | 05:16 PM
  #96
t6378tp's Avatar
Turbo 3.5
glad to see your tossing in another motor, enjoy
Old Apr 18, 2012 | 06:21 PM
  #97
Quickywd01's Avatar
Nice to see the new motor. Sad to see the carnage.
Old May 17, 2012 | 09:44 AM
  #98
Flava_24/7's Avatar
Boosted Panda
Update for those that care,
Panda should be up and running soon.
As I stated before, Ive already aquired a replacement motor with 45k.
Dropped it off with Stephen Max and he has completed the installement of the HR valve springs, HR head bolts and the Rev Up oil pump.
THANK YOU STEPHEN!
Jim Wolf has my ECU and injectors and hopefully they can get it tuned soon. Ive had some issues with the injectors being used and have gone back and forth with them a few times.
Once time allows I will be dropping the motor in, spare time is a bit scarce right now. I fly out to DC for a week, come back and go right back out of town for the weekend to attend my daughters soccer tournament. Following week I fly out to Baltimore and then who knows, hopefully I can get the motor in before anything else pops up.
If so, the plan is to drive on the JWT tune and if time/cash allows have it fine tuned with the EU later. Im wanting to dyno it with the JWT tune once its running just to see where my power level is at running just that tune.
Fingers crossed I dont run into anymore unforseen issues.
Old May 17, 2012 | 11:06 AM
  #99
J2FRESH's Avatar
GL
Old May 17, 2012 | 11:40 AM
  #100
Wish ya luck man.
Old May 17, 2012 | 12:58 PM
  #101
93altima's Avatar
Turbo 4th Gen
nice glad to hear
Old May 17, 2012 | 02:16 PM
  #102
t6378tp's Avatar
Turbo 3.5
Glad to hear
Old Jun 23, 2012 | 12:27 AM
  #103
TheArtist's Avatar
im glad you are keeping it. you had me worried there. no more panda would have been a sad day indeed!
Old Jun 25, 2012 | 05:44 AM
  #104
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
glad this finally worked to you keeping it. Ive been jocking that car since i had my 4th gen.
Old Jul 17, 2012 | 04:22 PM
  #105
ObsidianIce69's Avatar
Update!
Old Jul 17, 2012 | 05:37 PM
  #106
Quickywd01's Avatar
Old Jul 17, 2012 | 07:21 PM
  #107
Old Jul 18, 2012 | 05:15 PM
  #108
Flava_24/7's Avatar
Boosted Panda
Havent had much time at all with my daughter soccer games plus my own but I dropped in the motor last weekend. Just need to hook everything back up, put the radiator in and install the SCer. Hopefully it will be running by this weekend.
Old Jul 19, 2012 | 09:09 AM
  #109
Quickywd01's Avatar
Keep up the good work.
Old Jul 21, 2012 | 05:37 AM
  #110
Stillen Maxima's Avatar
Pay to Play
Good stuff man. Glad to hear install is moving along
Old Aug 10, 2012 | 09:16 AM
  #111
Quickywd01's Avatar
Old Aug 30, 2012 | 05:56 PM
  #112
Snypa's Avatar
How's the panda running now !?
Old Aug 31, 2012 | 08:05 AM
  #113
Flava_24/7's Avatar
Boosted Panda
Meh, its running but it appears I have some grounding issues.
Had problems with the starter so I put power and ground directly to it, it turned over right away and ran pretty smooth although it was really rich. CEL came on, checked codes MAF, and some EGRC stuff, all of wich ground in the same area as the starter.
I havent touched it since. I literally have had no time, and its getting depressing. My daughter plays soccer, as well as myself. Shes had multiple games every weekend and I have mine on Fri/Saturdays.
She only has one game this weekend, and its a holiday weekend so I plan to work on it Sun/Mon.
But with Hurricane Isaac, Ive been pretty busy at work and am on call this weekend so we shall see how that goes.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
