ve30de turbo manifold
Old Nov 6, 2014 | 06:32 AM
TonyJr's Avatar
Should i install a flex pipe in between my custom y pipe manifold for my turbo.
Old Nov 6, 2014 | 07:24 AM
krazy6's Avatar
Yes, you should definitely have a flex pipe in there.
Old Nov 6, 2014 | 07:58 AM
TonyJr's Avatar
Cool now i have to just find out what injectors to use for 250hp to 350 hp. Is it true that ve injectors are the same as 4th gens
Old Nov 9, 2014 | 07:21 AM
vipervadim's Avatar
I like Maximas
if you have the same side-feed red top 270cc as the vq30de 95-99 (00-01+ are top-feed)
then you can use the vg30dett 300zx twinturbo 370cc injectors (purple tops)
http://www.ebay.com/itm/NISSAN-300ZX...a3e51f&vxp=mtr
I believe the vg30dett's sr20det's and q45 - use the same 370cc purple top injectors.
Old Nov 9, 2014 | 09:55 AM
t6378tp's Avatar
Turbo 3.5
depending on the design a flex isn't needed
Old Nov 12, 2014 | 03:38 PM
TonyJr's Avatar
I saw the pic on ebay link and it the same style. Im going to start searching for a good set.
And my turbo manifold design is a reverse y pipe. As for the tuning for fuel do you think a Vsafc is good enough for a daily driven car.
Old Nov 13, 2014 | 03:11 PM
vipervadim's Avatar
I like Maximas
Yes. Here's a good fuel system setup for 250-350hp
1. apexi V-afc2 (overlap both maps to get 24 tuning points)
2. Adjustable fuel pressure regulator (tune base pressure if too much/little fuel or if you decide to go with bigger injectors and more boost later)
3. 370cc injectors (maybe clean/flow test them if you have a local spot)
4. walbro 255lph fuel pump (gotta be able to feed those injectors with the go juice)
this will also work for 400hp with bigger injectors, like 440cc+ but you will want more engine (fuel/timing)management and a bigger MAF (Z32tt) to get there safely.
Old Nov 14, 2014 | 03:43 AM
TonyJr's Avatar
I definitely like the first setup. I just want boost and I'm not looking to be the fastest maxima. I'll be video recording all my work. When I'm done I'll start a thread for all the ve guys that wanted to boost there maxima. All i have left is to but a good turbo and find injectors
Old Nov 14, 2014 | 06:52 AM
t6378tp's Avatar
Turbo 3.5
I think z32/q45 injectors what on 3rd gens too
Old Nov 14, 2014 | 08:52 AM
Crusher103's Avatar
I would definetely look into a emanage over the V/Safc. not much more of a price difference and much better for boost. ie you can tune off of boost.
Old Nov 15, 2014 | 06:04 PM
akurtzer57's Avatar
Tony I have set of z32 tt injectors I'd sell cheap.
Old Nov 16, 2014 | 10:08 AM
vipervadim's Avatar
I like Maximas
Crusher, I would normally agree with you (I still have EU on my 3.5L since '07)
But the OP (TonyJr) has a turbo'd VE30de engine not a VG/VQ engine
Because it's a VE30 I actually think an AEM FIC-6 will work better than v-afc2/emanage in his case (since you can't connect EU to a VE30 like you would on a VQ30 with crank/cam signals)
with AEM you can tune total injector PW control, Map sensor for boost, ability to retard timing and it datalogs (vafc2 does not datalog). FIC just needs a AEM UEGO to interface/log WBo2 reading and you're set..
price range of FIC-6 is between a vafc2 and emanage ultimate w/ harness. I've seen them ~$330 on ebay/forums just not a common find.
I've tuned with FIC6 before, it does take a little getting used to with various maps/screens and laptop USB interface. Same with an Emanage Ultimate but I'm just used to it.
It is simple enough to tune yourself (if you understand what you're doing), and can be brought to any qualified dyno tuner, since AEM is a well-known boost tuning solution.
http://www.aemelectronics.com/?q=pro...troller/fic-6#
http://www.aemelectronics.com/?q=pro...uego-afr-gauge
Old Nov 16, 2014 | 07:13 PM
TonyJr's Avatar
Thanks for the info.
How much for the injectors?
Old Nov 17, 2014 | 06:32 AM
TonyJr's Avatar
What do you think about a mircotech Lt8 standalone for my ve30de?
Old Nov 18, 2014 | 08:28 PM
akurtzer57's Avatar
Tony why don't you just go with nistune
Old Nov 19, 2014 | 01:22 AM
TonyJr's Avatar
I'm going to have to learn how to tune it cuz i don't think anyone here orlando fl knows how to tune it.
Old Nov 19, 2014 | 10:51 AM
TonyJr's Avatar
Do you think this would get me by to built my turbo y pipe turbo manifold?
http://orlando.craigslist.org/tls/4767201154.html
Old Nov 19, 2014 | 05:55 PM
akurtzer57's Avatar
Ya it could get you by. Obviously not high dollar setup. But could setup a scratch start tig setup. I recommend finding a dc stick welder and buying the torch setup. Miller thunderbolt etc. Has to be dc power source. Then you have name brand abd last year's. Also can be done around $400 with bottle
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
09maxshawn11
Sep 30, 2015 10:28 AM
dshinn
Sep 26, 2015 08:07 PM
