wheel spacers
Old Jun 10, 2003 | 09:11 PM
Maximan190's Avatar
wheel spacers
im considering using some spacers on my 99 16" rims; for appearance purposes to make them sit out more toward the fender lip
this is how it sits now with stock suspension
this is lordrandall's, notice the spacing in the rear.. i dont want anything that drastic, i think thats a 1" in the rear
soon i will be on eibach/tokicos and my question is, will it affect the balance of the suspension at all?....meaning that the center of weight (rim + tire) will now pushed outward with spacers
Old Jun 11, 2003 | 08:21 AM
Lordrandall's Avatar
Aaaaaaa!!! Those are from my "wide track" days, don't spread those around!!!
Here are pics with my new spacers....
(more on my homepage)
Old Jun 13, 2003 | 05:57 AM
StygianMax's Avatar
Did you buy longer studs separately or did they come with the H&R spacers? Also, how wide are they? 15mm?
Old Jun 16, 2003 | 11:42 AM
Those are not H&R's, they are custom CNC'ed from Crow Automotive.
They are 20mm with built in studs, you can tell by the pictures.
Check my homepage for all the info.
Old Dec 16, 2003 | 11:56 PM
crazy4maxima's Avatar
how much was the spacers randell...??
Old Dec 17, 2003 | 06:35 PM
Bman's Avatar
If the specs I've seen are right, I would say go no more than a 5 or 10mm spacer, because those wheels are supposed to be +40mm and our stock 15's are at +35mm. You should be able to fit 225 tires on them after that too.
Old Dec 17, 2003 | 06:38 PM
well they are 235-45-17 40mm offset.. but when i tunr i rub. weird cause only when i make full complete leff turns.maybe 5mm would do the trick.. how much do you think they are?
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
