Wheel Spacers..
Old Jun 20, 2003 | 09:34 AM
Raf2kMax's Avatar
Wheel Spacers..
anyone know about em??
i think my offsets only about 40 or 42 right now..around stock..
my bodykit comes out a lot.
how will the H&R spacers work for the car?? 5 mm in teh front and 10 mm in teh back??
is 10 too much???
Old Jun 20, 2003 | 12:06 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
i have 10mm spacers up front (to clear my big brakes).. it's not too much.
Old Jun 20, 2003 | 08:30 PM
Raf2kMax's Avatar
thanks ange
you sell em at your place?? installed too??
Old Jun 20, 2003 | 08:43 PM
Nealoc187's Avatar
SLOW
Originally posted by Raf2kMax
thanks ange
I have 15mm spacers just installed tonight in fact. I thought it would be too much but it looks perfect actually. outside of wheel is just flush with the fender. of course that depends on what wheels you have but mine looks good.
Old Jun 20, 2003 | 09:12 PM
Nathan's Avatar
What spacers do you have? The H&R's? If so, were the studs that were provided long enough? How hard is it to remove the stock wheel studs? Thanks,
Nathan
Old Jun 20, 2003 | 11:49 PM
97MaxGurl's Avatar
thanks ange
yes I can order it for you
yes I can have it installed for you too.
Call or email me so I can get you pricing and quote for the job.
AnGe
Nathan- Yes, the studs that comes with the H&R spacer kit should suffice. Knocking off stock wheel studs is a pain if you don't have the right tools. When replacing the stock studs with extended ones, you also want to be sure it is fitted in the wheelhub correctly and accurately. IMO, seek an experienced mechanic to replace your wheel studs so you won't deal with potential problems if the job is done half-assed.
Old Jun 21, 2003 | 09:10 AM
Nealoc187's Avatar
SLOW
Nathan
No I made my own. I had to buy Nismo 60mm studs, they aren't cheap. Stock ones aren't hard to remove you just bang them out with a sledge hammer, but putting new ones in can be tough. If you have access to air tools its easy as pie, if not, you have to tap them in with a hammer as far as you can get em, then put a few washers on the stud and start tightening a lug nut down on it. It takes a while, but it works. I did 5 of them yesterday that way, took probably 30 minutes. Then I realized I could just use the air ratchet and had the other 5 done in about 5 minutes.
Old Jun 21, 2003 | 09:23 AM
Nathan's Avatar
Thanks ange,
my next door neighbor is a Toyota brake specialist so I shouldnt have a problem getting him to do it for me
Old Jun 22, 2003 | 08:53 AM
Raf2kMax's Avatar
thanks ange
do the H&R's come in a set of 4 or can i order 2 10 mm spacers and 2 5 mm spacers?
ill probably let you know sometime in either july or august..
prices on em shouldnt be too much..
just gotta 5 speed swap, catback and a whole lotta other things on my car...i gotta calm down for a couple of weeks
Old Jun 22, 2003 | 09:19 AM
97MaxGurl's Avatar
thanks ange
H&R kits come with set of 2 (10 extended wheel studs)
Old Jul 14, 2003 | 07:19 PM
mitch33x's Avatar
I need some
Old Aug 12, 2003 | 05:13 PM
Raf2kMax's Avatar
hey ange..expect a call either tomorrow or thursday for sundays event
i might need to buy a couple of things
i can stay til only like 12:30ish though..
i have an offset of either 40 or 42...since im running 18 x 7.5's my rears look really indented or whatever..i dunno if i should get 10's or 15's..anyone have any input on em?
Old Aug 12, 2003 | 06:01 PM
97MaxGurl's Avatar
H&R in CA won't have any 15mm spacers for Maxima application to distribute until end of August. H&R doesn't even make 10mm spacer for Maximas
Email or PM me your contact # in case I need to get in touch with you.
AnGe
Old Aug 12, 2003 | 07:33 PM
C3nthusiast's Avatar
Re: Wheel Spacers..
I use a 15mm spacer on the rear. The lug holes in my rear wheels were bored out to accomodate ET lugs. They actually sink into the wheel to get as much thread on the stud as possible. If I take the spacer off the lug nut almost threads down to the rotor.
Old Aug 15, 2003 | 03:40 PM
Hamy's Avatar
Where could I pick up a set of wheel spacers? Either 10mm or 15mm?
Old Aug 15, 2003 | 06:22 PM
97MaxGurl's Avatar
I usually carry the H&R 5mm and 15mm spacers but H&R in CA won't have any 15mm spacers for Maxima application to distribute until end of August. H&R doesn't make 10mm spacer for Maximas
Old Aug 16, 2003 | 01:21 AM
Go to Pep Boys. $10 for 10mm.
Old Aug 16, 2003 | 06:36 AM
97MaxGurl's Avatar
you get what you pay for.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
