HELP!!! Marker on wheels
Old Jul 21, 2003 | 10:53 PM
Mkang513's Avatar
I just purchased these wheels from an org member. I noticed that the lettering on the center caps were fading. Upon closer investigation, I found out that they were filled in with marker!! How can i safely remove ALL of the residue from the center caps without harming the finish? Any suggestions??
This is what they should look like
On mine, parts of the "SSR" are colored in.
Old Jul 22, 2003 | 12:04 AM
Bman's Avatar
Sometimes rubbing alcohol will remove "permanent" marker. If not, any mild polish (don't use metal polish) should do it.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
