wheel size vs. acceleration
Old Jul 28, 2003 | 03:27 PM
sean96SE's Avatar
At some point I was thinking about getting new wheels to replace the 15" steelies on there now, but I don't want to sacrifice much if any acceleration. Would there be that large of an effect to go to lightweight 17" rims that weigh 15-20 lbs, as opposed to my steels that weight ~45? If so, what about 16" instead? Just wondering how much the rotational mass increase will hurt acceleration...
Old Jul 28, 2003 | 05:26 PM
MrGone's Avatar
it will help it as long as the overall diameter of the tire is equal.
Old Jul 28, 2003 | 08:19 PM
ThurzNite's Avatar
Depends on where the mass is. I had 3rd gen SE rims/tires for a while (stock stealies were bald). Then I got 18" rota subzeros w/tires. I put them both on a digital scale and they weigh the same. however, the 18" definitely slowed my straightline acceleration. the 18" rim itself was 17lb, but w/the tire on it just sucks.
Jae
Old Jul 28, 2003 | 08:39 PM
maxspeed96CT's Avatar
The original VQ...
sorry to **** your thread but i got 17s silver and it didnt slow me down, but i wam wondering if 18s chrome would?
Old Jul 29, 2003 | 10:56 PM
ivelweyz
sawblades only weigh 16.5 lbs...
Old Jul 30, 2003 | 06:27 AM
sean96SE's Avatar
really?? I don't know where I read that they were 40+ lbs. but I guess you can't believe everything you read. thanks
Old Jul 30, 2003 | 07:48 AM
ThurzNite's Avatar
They are closer to 40lb w/the tires.
Jae
Old Jul 31, 2003 | 06:15 AM
JMF's Avatar
JMF
It depends on how much rotational inertia the wheels/tires have...which is dependent on not only the mass of the wheel/tire combo, but how far out from the center of the rim.
As a rule of thumb, each pound of weight on your wheels will affect your car like four pounds on the chassis, (from an acceleration/braking standpoint and assuming the moment of interia is the same from each combo)
For instance, I put Fikse FM10s (17 lbs each)on my '98 Camaro, then I put rear 275/40/17 out back (31 lbs each), and 255/40/17 up front (26 lbs each). These replaced my stock rims (26 lbs each) and original tires (31 lbs each). My total rotating mass was reduced by 46 lbs, which will seem like [about] 184 lbs on the chassis. It was like NOT having one of your buds in the car. Also, the suspension carries less inertia, so it can react quicker, thus improving your handling AND ride.
Good luck--Justin
RinconI30
Nov 10, 2015 10:55 PM
minsbang
Sep 11, 2015 08:48 PM
jcvgn
Sep 10, 2015 08:03 PM
dcam0326
Sep 8, 2015 11:02 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
