H&R Wheel Spacers
Old Aug 2, 2003 | 01:48 PM
mindhead1's Avatar
H&R Wheel Spacers
Has anyone installed H&R Spacer on a Maxima with OEM wheels?
I am interested in feedback on how this might affect the cars drivability (vibrations, alighnment trouble, etc.)
I have a '99 SE that I am to have lowered with H&R springs and KYB shocks. I have seen others like this with stock wheels that just don't look right in the wheel well.
Thanks!
Mindhead1
Old Aug 2, 2003 | 01:51 PM
Nismo's Avatar
5mm spacers all around. as long as you installed the supplied longer wheel studs your fine.
Old Aug 2, 2003 | 02:03 PM
mindhead1's Avatar
Nismo! Thanks for the quick reply.
Are you recommending the 5mm because they are the right size for stock wheel or because the bigger spacers (15mm or 20mm) are just to much?
Old Aug 2, 2003 | 04:46 PM
Nismo's Avatar
only reason I used 5mm is so that my rims wont rub my fender since I had a 48mm offset. 15mm would look nice though but I didnt want to spend that much for them because 5mm is all I needed.
Old Aug 4, 2003 | 01:42 PM
andy21's Avatar
where can u buy wheel spacers?
Old Aug 5, 2003 | 09:28 AM
soundmike's Avatar
Very sound, Mike
Check out OptAuto.com
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
