**PLEASE HELP** Anyone With Rims
Old Sep 18, 2003 | 04:00 AM
95nissanMax's Avatar
Ok heres the problem. My parents have decided that the maxima needs new tires. So me taking every advantage of this thought it would be a perfect time to get some nice rims put on the car.(since all i got now are just hubcaps) Well at first my parents seemed alright with it...so i went and picked out the rims i like. The rims are 17x8 and i can get a good deal on them. But... a mechanic at my dads works said that by puttin on bigger rims then the car was made for it can mess up the axles or joints or something like that. so is this true...? If not please help me and prove this guy wrong. Or even just tell me what size rims you have and how long youve had them and if youve had any problems with them.
this would help out sooo much
thanks in advance!
Old Sep 18, 2003 | 04:06 AM
happyricefob's Avatar
V^___^V
ugh...no?
Old Sep 18, 2003 | 06:10 AM
97GLES's Avatar
Originally Posted by happyricefob
ugh...no?
17" will be fine, i thnk most ppl go with 235/45/17 tires. don't forget the the se comes with 16" wheels.
i have 19x8 for almost 2yrs. and have no problem.
Old Sep 18, 2003 | 06:46 AM
d_warner's Avatar
Old Timer
18X8s here and no problems with axles except for my VERY aggressive driving style. At one time, I put 17X9 Cobra rims with 275/40/17 tires on the front of the max just for fun. They looked like drag slicks, and I still had no problems. You'll be fine with 17's. Go for it.
David
Old Sep 18, 2003 | 06:48 AM
worm's Avatar
I have 18x8.5" rims on my maxima and ive never had a problem. if you do get bigger rims you probably will want to get your car lowered though just because it will look "raised"
Old Sep 18, 2003 | 07:26 AM
Ninos_Maxima's Avatar
be the change u want2C
17x7 No problems at all, You should tell your Mechanic to go eat a Hamburger cause your car aint no peice of crap to brake apart like that!!!
Old Sep 18, 2003 | 07:30 AM
Ceasars Chariot's Avatar
Old Maxima Legend
You Your Mechanic !!
Be sure to tell him he got --->
Old Sep 18, 2003 | 07:46 AM
endus's Avatar
An atavistic endeavor...
Waht?! That mechanic is smoking crack. People put rims on cars all the time...the 2k+ max COMES with 17's...dude is straight BSing
Old Sep 18, 2003 | 08:43 AM
Abimax95's Avatar
thanks in advance!
man he is full of what comes out of his a**....go to www.wheelmax.com
I haven't seen any beat there prices and FREE SHIPPING.......
Old Sep 18, 2003 | 08:45 AM
MAXimumHP's Avatar
Just ask your mechanic how that is going to adversely effect the axles and joints and see what kind of baloney story he gives you. As long as you keep the same overall diameter and a close offset, all the geometry and forces on those components remain nearly the same. What, is he worried the larger rims may snap the driveshaft or something
Old Sep 18, 2003 | 08:55 AM
ivelweyz
Since when? 96-96 ONLY HAVE 15s...
Old Sep 18, 2003 | 10:48 AM
mchne's Avatar
your mechanic is either an idiot, or your parents are so against getting you the rims that they decided to tell him on the side to convince you not to buy them.
Old Sep 18, 2003 | 11:49 AM
ivelweyz
Well the allignment will be off so he is kind of right. He probably did tell your parents about the allignment, they just blocked it out...
Old Sep 18, 2003 | 12:42 PM
maxNYC's Avatar
maybe your mechanic is referring to large rims on a slammed maxima....
otherwise, tell me to stay off the doobie...
Old Sep 18, 2003 | 04:04 PM
ivelweyz
you mean tell him to stay off the doobie???
Old Sep 18, 2003 | 05:49 PM
thanks alot for your response
this is why i love this place
Old Sep 18, 2003 | 07:43 PM
well that didnt work
my dad is set on getting 15's
he thinks that the bearing and all this are not in the best condition so the car doesnt need 17's
soo now... im on the search for some really light wieght rims for round the $400 range
Old Sep 19, 2003 | 08:14 AM
Abimax95's Avatar
Dude go to www.wheelmax.com good luck !!!!!!!!!!!
Old Sep 19, 2003 | 08:25 AM
maxNYC's Avatar
well 15's will serve you well. Might as well use the stock ones and use the cash for better tires
Old Sep 19, 2003 | 08:42 AM
asu174's Avatar
Clay Aiken has fancy genitals
I really don't see the point in buying 15" aftermarket wheels. Just stick with the hubbies for now.
Old Sep 21, 2003 | 11:09 AM
Bman's Avatar
thanks in advance!
Okay, here's the deal. Putting a bigger wheel and tire combo on a car won't cause any damage directly, BUT they can be harder on components, which might be what the mechanic is trying to get at (but probably doesn't know it ). There are a few reasons for this. The first is because larger wheels and tires are usually heavier than stock, which will put more strain on the suspension in general as it works to keep it in place and when it bounces around. Second is if you change the offset of the wheel a lot, which can strain the bearings more because of the different leverage. Also large, low profile tires transmit more of the road's imperfections and bumps up through the suspension (you'll feel it through the steering wheel) than our poofy stock tires do.
That said, lots of people run 17" wheels without problems it seems. Just make sure they're between +30 and +35 (stock btw) offset. Or you can split the difference and suggest 16" wheels like those off of 4th Gens or something. They'll still look good and be a handling upgrade, but won't be as heavy or ride as hard. Just be CAREFUL what style of wheel you get if you absolutely must get 15" wheels. Ask DA-MAX about his 15" bus tires and you'll see what I mean. Our stock rims look good now only because they don't have a lot of empty space in them, so the tire looks smaller. Put 5-spokes on there with lots of empty space in them, and you'll get the bus tire effect... HTH, and good luck.
Old Sep 22, 2003 | 12:01 PM
DoGGy
Your Mechanic Can Kiss My ***. If It Was Like That, Nissan Wouldnt Ship Maxima Gxe And Gle With 15" And The Se With 16"
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
