Someone explain why 235/50 will fit but 235/45 will not
Old Sep 29, 2003 | 07:10 PM
FUEL
I do not understand why it says in the FAQs that 235 / 50 will work and not the 45's. It is just a sidewall height is it not? The 45s would be slightly smaller so why is it that they would not fit??!?!?!
Old Sep 29, 2003 | 07:22 PM
nissan5788's Avatar
IIRC they should fit, speedo error might be a concern though but I'm not too sure on that. Try the search
Old Sep 29, 2003 | 08:08 PM
asu174's Avatar
Clay Aiken has fancy genitals
Sidewall flexion was the issue, but plenty of people are running them with no issues.
Old Oct 1, 2003 | 09:03 AM
johnny2kgle's Avatar
It is not recommended by the Tire and Wheel Association, but it can be done.
If you decide to do it, make sure that you keep the tires properly inflated.
Old Oct 17, 2003 | 09:13 PM
Roman-dude's Avatar
on 15" rims?
are you running 235s on 15"?
thanks
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
