Do 17" rims fit without any wheel well mods?
Old Oct 29, 2003 | 04:55 PM
Army-The-Sarg's Avatar
I'm planning on getting ADR Reaction 17" x 7" Rims and I was wondering if they will fit without any modifications. The tire size is 235/45-17
Old Oct 29, 2003 | 04:56 PM
Iron Scimitar's Avatar
Tha Snatcher
they should fit perfect. make sure u get hub rings.
Old Oct 29, 2003 | 06:19 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
if u have abs, make sure ur get the right tires so ur abs light doesnt go off
Old Oct 29, 2003 | 06:39 PM
limsandy's Avatar
Depends on the offset.
~limsandy
Old Oct 29, 2003 | 08:17 PM
Bman's Avatar
Just thought I'd let you know that 235/45-17 is actually too wide for that wheel... unless you've been hanging around too many 5th Gen guys or something.
A tire shop may mount that for you, but they'll probably tell you they're not liable.
Old Oct 30, 2003 | 03:58 AM
where can i get hub rings? The offset on my new rims is +42
Old Oct 30, 2003 | 08:32 AM
hollaatchaboi's Avatar
Originally Posted by slammed95
I hope you want the hub rings just to center the wheels, and not to change the offset.
Hopefully you either got wider wheels, or aren't gonna use the 235/45's. Those tires are 9.6" wide and wouldn't be very safe on a 7" wheel.
Seriously, any wheel less than 8" wide on maxima is too small. My 9" wide wheels look just right on the maxima, ad the back could be just a little wider still.
So what size tire would you suggest for a max w/ 17" wheels that are 7" wide. Everyplace i go tells me that 235/45 wheels are what i'm suppose to get. I see in MAXFAQ's it suggests 215/50.
Old Oct 30, 2003 | 09:37 AM
foetray's Avatar
The Faq's suggest that size because it is, or reasonably close to, the overall tire diameter of the OEM tire. You need to stay close to that because if you don't it will throw off the speedometer ( faster or slower than actual speed depending on tire size ) and send a false signal to the speed cable the transmission uses causing problems with the transmission. If the FAQ's suggest a 215/50/17, that means your overall tire diameter is around 25.1
Old Oct 30, 2003 | 04:17 PM
where can i get the hub rings if i need them though? and anyone who has 17"x7" rims, let me know what tire size you use...
Old Oct 30, 2003 | 07:00 PM
Bman's Avatar
Usually you tell the company you buy the wheels from what kind of car this is for, and they will (or SHOULD!) include the proper hub rings to mount the wheel on a Maxima. You should definitely get and use hub rings with your wheels if you can. Do you know what hub rings are and what they do?
A 235/45 tire will also mount on a 7.5" wheel, as this in within spec. How it handles is something I have no clue about, but 7.5" is the approved minimum size for 235/45 tires. That's why there's all this fuss about folks putting 235/45 on their 5th Gen wheels and other 7" wide wheels, as it is just out of spec.
Old Oct 30, 2003 | 10:04 PM
Logan91VE's Avatar
for a 7" wide rim the max width you should go is 225, 235 is just too wide.
Old Oct 30, 2003 | 10:20 PM
asu174's Avatar
Clay Aiken has fancy genitals
WTF? ABS light? OMG.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
twotonezed
Aug 16, 2015 11:41 AM
