Re: (Help) Staggered Wheels
Hello Fellow Maxima Drivers....I need your opinion. First of all i am purchasing a set of volk racing SF winning 19x8.5 and 19x9.5 offset 38 (front) and offset 42 (rear). Now do you guys think that i would have a problem fitting it to my car any suggestion will help me in making the right decisions. Thanks. [COLOR=Navy]
Originally Posted by slammed95
The 8.5" 38mm offset should fit just right in the front, but the rears might not fit. The tire may rub on the spring with a 42mm offset on a 9.5" wide wheel. 35mm might work though.
What size tires are you gonna be using? 275/30 would be just right for the rear wheels.
I think you should be okay..... do you mind deleting the other post?
~limsandy
Re: Thanks for your response
Hello there guys.......Thanks for your kind advice. So as far as my new wheels in concern i should be getting a (19x8.5 w/42/front) and (19x9.5 w/38 rear). Tell me if this is the sweet spot for my car. Also, i am planning to get either a 265 or 275 for my rear tires. I need your opinions. Thanks
Oh about the wheels....well i am getting that Volk racing SF winnings. If you guys have time you can check out the website at WWW.mackinindusties.com and tell me the offsets. thanks
ooppss its www.mackinindistries.com
Andy29
09-29-2015 05:32 AM
