No traction in cold weather
wtf....blah...stupid thing timed out and i lost my whole thing.....
ok, anyways...i was out early this morning and temperature was 32 degrees. i floored it and it was pulling but i didnt have traction for at least 50 feet. is this due to the cold tires or just because my tires suck? i have contintel touring contact as that were on the car when i bought it
http://www.conti-online.com/generato...enefit_en.html
front two tires are getting low but back two tires still have tread left. is it alright to just replaced front two tires or is it recommended i do them all at once even though the back tires are good. i am looking into getting some of those falken ziex 512 tires but for 4 tires of 215/55r16 it will run about 460 since the tires cost about $115 each. are there any other places that sell them cheaper?
Originally Posted by Ammi
cold temperature will slightly lower the tire pressure. Hot temperature will do the opposite. If you just have bad traction, its the tires.
Just to let you know, all non-snow/winter tires will have decreased traction when the temperature dips that low. It's just a function of how tire makers have to make the rubber compound so that it can (sort of) work in all 4 seasons. Cold temperature makes the rubber harder, so it has less grip.
The Falkens may or may not be an improvement, no one can tell you for sure. Keep in mind that it is supposed to be a high performance A/S tire, so that means it's design is biased slightly more towards handling and/or wet grip, and probably less for icy weather. I don't know for sure, that's just my best guess.
Originally Posted by bigdo26
ya rubber gets harder in the cold = less traction. i have the same problem. tires just love to spin in the cold. but the engine loves cold air huh?
When the thermometer really drops, you can forget about tire pressure, tread design and tread wear of your all-seasons because you're basically driving on four hockey pucks. If winter happens where you live, 4 snows are the way to go. All season tires are a year-round compromise.
Cheers,
Jaeger
You know experts recommend deflating tire pressure so you get more grip on snow
I'm running 225/55/16 Continental ContiExtreme's (high performance all seasons) for my winter tires and they seem to be minimally effected by low temperature. I was pleasantly surprised. You might want to check them out. Tire Rack has them for under $100 a pop.
Yea I was going to say, I don't think people in this Org are dumb enough to deflate the tire so much that they look like flat tires I was thinking 3-5 lbs max.
tarun900
19
12-20-2021 06:57 PM
TKHanson
11-24-2018 01:39 AM
Serotta33
09-17-2015 12:14 PM
