View Poll Results: What would u do?
I would just buy wider wheels!
59.09%
I rather just get spacers....
27.27%
i don't care... =P
13.64%
Voters: 22. You may not vote on this poll
y don't ppl buy wider wheels instead of spacers?
Old Dec 26, 2003 | 10:53 PM
myktek's Avatar
i've notice alot of ppl lately have been getting spacers for there cars...and i think to myself and say...y buy spacers....y not just buy wider wheels.... personally i just think it looks much better w/ a wider wheel then using spacers....let's have a poll
Old Dec 26, 2003 | 11:02 PM
Link112's Avatar
I like the stock look not to mention the cost of new wheels and rubber. Can't stand the tuck look in the back, but don't want the front sticking out either. $165 or so for spacers or $800+ on new wheels.
Old Dec 26, 2003 | 11:09 PM
MyownNismo's Avatar
Future Camaro SS owner
Cause the Wheels I bought only come in 35 and 45 offset. I got 5mm spacers for the back to bring them to 30.
Old Dec 26, 2003 | 11:54 PM
limsandy's Avatar
I voted for wider wheels and I won't put spacers unless there's only one kind of wheels in this world.
~limsandy
Old Dec 26, 2003 | 11:57 PM
limsandy's Avatar
I believe Axis Hagens with 35mm offset will fit perfect on 5th gens, no?
~limsandy
Old Dec 27, 2003 | 12:02 AM
HNDA ETR's Avatar
Still Here... IM me for more..
well i'm in socal... i see spacers all the time...
usually on slammed mini-pickups with 14" wheels and the wheels stick out 3" past the fenders
also, you gotta be carying landscaping equipment to do it...
MyownNismo's Avatar
~limsandy
They do just they looked tucked in the back. I am going to put the 5mm on in spring if I don't like them I will take them off.
Old Dec 27, 2003 | 01:01 AM
ChromeSE5's Avatar
Price. I wanted some Milles and some dude quoted me for $2500. For that much i might as well get blown... supercharger that is.
Old Dec 27, 2003 | 01:02 AM
HNDA ETR's Avatar
LOL...
Old Dec 27, 2003 | 01:09 AM
limsandy's Avatar
My advice is.... don't get spacers at all. It's your call though.
~limsandy
Old Dec 27, 2003 | 02:08 AM
MyownNismo's Avatar
If they where bad then H&R wouldn't sell them.
Old Dec 27, 2003 | 07:55 AM
HKMax's Avatar
People get spacers for various resons. For me it was a clearance issue. The wheels I got are 47mm offset (I didn't know that when I got them). Since I needed to get spacers I might as well get wide enough ones so the wheels get pushed out so they look some what flush with the fender. If I had to do it all over again I would get 35mm offser with 8" wide rims. But given the circumstances spacers are good option. Besides, spacers like H&R should not have adverse affect on suspension.
Old Dec 28, 2003 | 12:03 PM
MyownNismo's Avatar
Originally Posted by slammed95
People are gonna get them somewhere, H&R might as well make money off them.
Simply get the correct firment from the wheels. Choose the right width and offset, and everything will be good.
yeah but like I said my wheels which I wanted since I first saw them only come in 35 and 45 offset. The front is perfect the rear needs to come out a little bit reason I am going to try the 5mm spacer in the back and if I don't like it I will simple just take them off.
http://www.axiswheels.com/hagen.html
Old Dec 28, 2003 | 01:34 PM
Bman's Avatar
Personally I think buying spacers purely for cosmetic reasons is a dumb thing to do. The reason why people should be using spacers is to allow them to fit tires/wheels that would otherwise not fit, as in some of the cases above. Ideally, you should be buying wheels with the proper offset in the first place, but sometimes things don't work out that way for various reasons.
Spacers shouldn't be used unless you have to because it adds more mechanical complexity, and isn't exactly cheap if you want to do it properly. Besides that, I don't think that some of the spacers some people would like to use to alter their car's appearance, such as 10mm spacers, would really make that much difference for the amount of time and money it costs them.
If you want to get the tires closer to the fenders and give the car a wider stance you should IMHO:
1) Get a set of wheels with lower offsets.
2) Get a set of wider tires (often requires wider wheels).
3) Get wider tires on wider, lower offset wheels. I think this is probably most common because you can end up filling the wheelwells 100%, and get more traction as well.
My $0.02
Old Mar 25, 2004 | 08:04 PM
Hamy's Avatar
Ok I figured I might give my opinion on this a little bit. My wheels 19x8 are a 45 offset. For those who are thinking WTF was he thinking buying a wheel with that offset...well I didnt know any better. I just bought the wheels because I liked the look of them NOT because of their fitment. So my only option was to get spacers. 5mm front and 15mm rear. Now everything is perfect looking. It very easy for someone to say blah...get a wider wheel or get a lower offset....but honestly its a little hard to change things after the fact. I mean hell the wheels cost $600 each not to mention the custom powder coating...then you add tires. To say the least spending $100 on spacers was not a problem at all to make it look better. YES if I could do it again I would have got a 35 offset all around with a 19x8.5. But I guess that will have to wait till the next set of wheels.
Old Mar 26, 2004 | 03:01 AM
Ammi's Avatar
350 Detroit Muscle
If rims you want don't come in offset you want, use H&R spacers. Otherwise, just get the rims w/ correct offset.
Old Mar 26, 2004 | 04:52 AM
billy_corgan's Avatar
Can someone breifly explain offset to me?
Old Mar 26, 2004 | 05:44 AM
Ammi's Avatar
350 Detroit Muscle
Offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel.
Lower the offset, further the wheel stick out.
Old Mar 26, 2004 | 06:29 AM
Mizeree_X's Avatar
Getting back to his roots
I have 6mm spacers in the back of my car, because the wheels I bought were +45 offset, which is too high for my IRS. For all those who say, "buy the correct size", if you want to point me to a set of 18" SSR Integral A2s with the proper offset, for 50% off retail, I'll put my set on Ebay and buy them.
Old Sep 30, 2004 | 06:39 PM
pvaudo's Avatar
"""Offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. Lower the offset, further the wheel stick out."""
I don't get it... I thought spacers increased the offset, bringing the wheels OUT, but I think you're saying spacers will bring them further IN???
Old Sep 30, 2004 | 07:08 PM
matt90max's Avatar
I have a 3rd gen and i found a deal on some 19s with small tires. I had to buy 1 inch adpaters to make them fit but it worked out good for me. better stance but lighter weight then a 8.0" or 8.5 inch rim. which was a good for my old max.
Old Sep 30, 2004 | 07:56 PM
Mizeree_X's Avatar
Yikes, this thread is back from the dead. Spacers decrease the positive offset, and therefore push the wheels farther out. The higher the positive offset, the further the wheels sit in the fender. Tirerack has a good explanation and picture of how offset works.
BTW, I now have 1/2" spacers in the front to clear my BBK
Old Sep 30, 2004 | 08:01 PM
Ammi's Avatar
350 Detroit Muscle
Spacers will decrease offset number. If you have wheel w/ 40mm offset and if you use 5mm spacer, your resulting offset will be 35mm.
Old Oct 9, 2004 | 12:01 PM
Triple8Sol's Avatar
I miss the .org!
There is a stickied thread in this forum for a wheel offset calculator that can help you understand how offset and spacers work.
I prefer not to use a spacer, but I do run a 5mm in the back, stock bolts of course. So effectively 37mm front and 32mm rear on 19x8.5 rims. There seems to be room for the wheels to be pushed out a bit more to fill up the wheelwell even better, so purely for aesthetic reasons...
Ben2003GLE
31
Jul 17, 2016 08:13 AM
incubusjohnny
Nov 3, 2015 05:18 PM
twotonezed
Aug 16, 2015 11:41 AM
Maxboy23
Aug 11, 2015 11:59 AM
