Potenza RE950: MAX PSI 44... What should I fill them to for everyday driving?
Old Dec 30, 2003 | 01:40 PM
white95max's Avatar
When I got my tires mounted last weekend, the mechanic filled them to 33PSI. It says MAX 44PSI on the sidewall. Shouldn't they be filled higher than 33?
Old Dec 30, 2003 | 02:54 PM
Jaws's Avatar
Somewhere between 32 and 35, but experiment to find out what works best for you. Anything higher than 35 and you risk having abnormal wear in the centre of the tire.
Old Dec 30, 2003 | 04:33 PM
kwd2kSE's Avatar
Watch the wear pattern on the tire.
Old Dec 30, 2003 | 07:40 PM
drewm's Avatar
http://maxmods.dyndns.org/index.php?TirePressure
Old Jan 4, 2004 | 05:31 PM
RapidMax's Avatar
35 is a bit high. I just got RE950s also and have been experimenting with different pressures. At 35, I could feel every bump in the road and the tires didn't stick that well. I've dropped pressure down to 33 in the front and around 31-32 in the rear and its much better.
Old Jan 4, 2004 | 10:41 PM
I30tMikeD's Avatar
I run 31-33 psi in my 950's, anything higher it gets too rough IMO
Maxboy23
Sep 8, 2015 06:53 PM
hydriplex
Aug 28, 2015 02:13 PM
maxinout93
Aug 20, 2015 02:17 AM
egali045
Aug 16, 2015 01:19 PM
doobadoo
Aug 15, 2015 06:43 PM
