18 x 9 in Rear, 18 x 8 front with 35 offset
Old Jan 6, 2004 | 09:18 AM
1phtmax's Avatar
I like the ADR Version II wheels but don't know if they fit or do i need wheels with higher (+)offset ??
Old Jan 6, 2004 | 05:16 PM
kwd2kSE's Avatar
The 18x8 with +35 offset will fit fine, even with 245/40/18 tires. But get the same size front and back so you can rotate tires.
Old Jan 6, 2004 | 05:24 PM
asu174's Avatar
Clay Aiken has fancy genitals
Yeah, your car isn't RWD and the whole "handling" argument is debatable.
I like those wheels a lot.
Old Jan 7, 2004 | 07:48 AM
1phtmax's Avatar
cool thank's
Old Jan 7, 2004 | 11:00 AM
wescoast_ryder
Originally Posted by slammed95
Go with the staggered setup. It will look better IMO, and handling can be much better than having the same size all around.
His car looks badazz in person with the wider wheel in the back. Going around on-ramps at 90mph, the car was planted! I think he said it's because you can increase the stiffness of the RSB without worrying about the rear end sliding as easily. He also has the fronts at -1degree of camber.
Go for 9", or 9.5" in the back. With a 40mm offset you should fit 275/35/18's, or with 35mm offset, don't go wider than 265.
Old Jan 8, 2004 | 09:04 AM
1phtmax's Avatar
If i do go with the staggered setup then 265/35/18 Rear and 245/35/18 Front and what springs do i get Tein's ?
Old Jan 9, 2004 | 02:57 AM
97GLES's Avatar
if your going to use the 265/35 on the rear for sure you should look into the 225/40 or 235/40 up front.
Old Jan 9, 2004 | 04:47 PM
limsandy's Avatar
Why? Handling with 225s would suck! 245/40 is the right size for 18's.
Depends on the width. Your statement sounds so general.
~limsandy
Old Jan 10, 2004 | 07:14 AM
1phtmax's Avatar
so 245/18/40 in the front will it rub in the back with 265? or do i have to roll my rear fender's
Old Jan 13, 2004 | 02:57 AM
97GLES's Avatar
245/40 is taller than the 265/35
it makes you look taller in the front. (your @ss looks like it's draging)
thats why i said to look at the 225 or 235
and 245 is not the right size for a 8" wheel. it should be used with a 8.5" wheel.
you might have to roll the rear fenders, it all depends on the wheel.
best thing to do is try them on.
Old Jan 13, 2004 | 10:03 AM
limsandy's Avatar
slammed95,
I said your statement sounds general because you didnt specify which size for the front or rear. "Handling with 225s would suck!" They won't if you have 225 in fronts and 265/275 in rears, with the right rim width. And they could give better handling than having 245 all around. At least, that's what I think.
~limsandy
Old Jan 15, 2004 | 04:52 PM
Ammi's Avatar
350 Detroit Muscle
Someone explain to me how having staggered setup would make FWD car have better handling.
Old Jan 22, 2004 | 10:15 AM
nupe500's Avatar
Jedi Knight
slammed95, you've got mail!
Old Jan 23, 2004 | 08:36 PM
1phtmax's Avatar
ok' my rims are on the way as well as tein springs
18 x 8 f 18 x 9 r 35'' off set
Old Jan 23, 2004 | 11:42 PM
limsandy's Avatar
Cool, what sizes are your tires?
~limsandy
Old Jan 23, 2004 | 11:57 PM
gunmax's Avatar
I have same wheel size with 245/40-18 on
Old Jan 24, 2004 | 09:16 AM
1phtmax's Avatar
do u have 245 F/B
Old Jan 24, 2004 | 09:48 PM
1phtmax's Avatar
Old Jan 24, 2004 | 09:51 PM
1phtmax's Avatar
sorry i dont know how to quote.
Still dont know what size tires yet but im doing the staggered look
Old Jan 25, 2004 | 09:57 AM
Raf2kMax's Avatar
would 18x8.5's fit without any problem in the rear with a 35 offset? i dont want any rubbing...
Old Jan 25, 2004 | 10:03 PM
Raf2kMax's Avatar
beautiful..thanks alot
Devo
18
Mar 7, 2016 07:36 PM
Huttig2009
Sep 25, 2015 03:31 PM
kenc15
Sep 25, 2015 06:38 AM
twotonezed
Aug 16, 2015 11:41 AM
