Enkei, Nakayama, or Konig (Quality/Value)?
Old Jan 16, 2004 | 12:29 PM
Colonel's Avatar
Old Fuddy Duddy
I am looking at getting "summer" rims. I currently have Konig Verdicts as my winter rims with Pilot A/S tires (225/17)
I am looking for new rims to put a cheaper rubber on for the summer and upsize a tad.
I am looking at rims from these manufacturers:
Konig, Enkei, Nakayama.
Since rim selection is a personal preference, I am leaving out the models. I am more interested in the quality of the manufacturers. Any one of those three NOT worth while or anyone one REALLY good? I do understand that these are not of the quality of SSR, but I dont have that kind of cabbage just for rims.
Also, for a 5th Gen max, I am looking at getting a 18 X 7.5 or 18 X 8, putting a 235/40/18 tire on it. But what should the bolt pattern be? 5 X 100? 5 X 112?
Thanks for information that you can provide.
Old Jan 16, 2004 | 08:11 PM
drewm's Avatar
Bolt pattern and offset are here:
http://maxmods.dyndns.org/index.php?MaximaWheels
And speaking of SSR, their rims aren't that strong, I've seen quite a few bent SSR Type-Cs and my brother bent a side of his 17" SSR Integrals. Out of those companies, I'd probably go with Enkei. I've heard many stories of bent and warped Konig Tantrums. And I can't even find a Nakayama's homepage online at all. Speaking of which, most of their rims look like cheap knockoffs of other brands.
Also, if you're getting 235 width, you will probably need an 8" wide rim, some tires might not fit on anything smaller.
Take a look around at that earlier link I sent for more manufacturers and sellers of rims, you might just find something else you like.
Old Jan 16, 2004 | 08:37 PM
Ammi's Avatar
350 Detroit Muscle
Bolt pattern is 5/114.3
Konigs are decent quality rims. Not sure about Nakayama.
If I had to pick one brand, I would go w/ Enkei. I had them on my other car for few years. Used to nail pot holes left and right w/ low profile tires. I had to replace few tires but never had issues w/ rims. They are tough!
Old Jan 19, 2004 | 06:25 AM
soundmike's Avatar
Very sound, Mike
Here's another vote for Enkei's. I got mine from Tan and between the two of us, we've logged so many miles on this thing on Houston potholes it's not even funny - and we both run 225/40/18's.
It's scratched, chipped, nicked and whatnot but it's still structurally sound.
Old Jan 19, 2004 | 02:41 PM
Colonel's Avatar
Old Fuddy Duddy
Cool!
Cause the Enkei were my favs...but since a BBK is on order...have to find "other" critical measurements now.... DOH!
Old Jan 20, 2004 | 07:09 AM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by slammed95
My Enkei's easily clear the BBK.
Well, I cashed out my rim money for the BBK. And once I verify that my "winter" (17" Konig Verdicts) rims clear it, I will be getting 18" summer rims which I HOPE will not be an issue (clearance issues) being 18"...But I have to make sure at 5.5" from the center of hub that there is 2.385" of clearance by the spokes. Minimum.
So, the rims are on hold for a couple months...but hey...summer is more than a couple months away . At least Enkei got the thumbs up! BTW, I was looking at the MM2's or RPM2's.
Old Jan 21, 2004 | 04:57 PM
MaxDoogie's Avatar
Enkei CP1's clear BBK fine
And I don't get what this talk about putting 235 tires on an 8 inch rim...225's are fine...Hell, look at the NISMO 350z's, they run 245's on a 9.5 inch rim and they fit just fine
I'll be running 8.5 inch wheels on the front of my 240sx with 225 tires and they will work just fine, too
Old Jan 22, 2004 | 01:19 PM
bsetiawan's Avatar
I would choose Enkei too.
Enkei RPO5
Old Jan 23, 2004 | 01:57 PM
Wisky97SE's Avatar
I thought i'd chime in on the tire size debate . . Im running 235's on a 7inch wide wheel and I have had no problems.
Old Jan 26, 2004 | 12:59 PM
C3nthusiast's Avatar
Enkei!!!!!!! 19 X 8.5 wrapped by 235/35-19.
Old Jan 27, 2004 | 05:50 AM
PAPA SMURF
eh.......I've never heard the words "konig" and "quality" in the same sentence being used properly...
but hey..whatever floats your boat
Old Jan 27, 2004 | 01:17 PM
Wisky97SE's Avatar
Konig wheels are NOT very high quality. Enkei are of good quality. I dont know of the other brand.
Old Jan 27, 2004 | 03:34 PM
You pay for what you get. My Enkei's cost me $4500 w/tires. You pay for what you get. The Konigs are affordable because they are cheaply made. And plus don't all Maxima's on the board have Konigs, Mille Miglia's, Lowenhart knockoffs, or Volks. Be different. All these cars look the same. Spend the cash!! You'll have more pride in your car. People notice the effort you put in your car. Don't spoil it by buying cheap stuff or wheels that everyone has.
Old Jan 31, 2004 | 01:14 PM
AllGo's Avatar
Enkei's are by far one of the best cast if not the best cast wheel on the market. Why do you think Toyota/Lexus choose these as their #1 choice for the oem wheels they use?
I have had a set of 17" x 8" RPO1's, that mind you weigh only 16.7 lbs. For over 3 years, 75k miles on 2 different cars. I have never had any wheel bend or had any balancing issues and the runout (perfect circle) of their wheels are second to none. These are extremely strong wheels due to there extra inner rim material where the spokes come in contact with the outer lip and very well priced also. I would probably get the newer RP02 with their hollow spoke design or the newest RSV design.
Old Feb 3, 2004 | 11:57 PM
Nealoc187's Avatar
SLOW
Enkei wheels are strong, pretty light, and quite unique. Unlike most other wheel companies that copy the designs of the more expensive "tuner" wheels enkeis are generally proprietry designs which you won't see knockoffs of.
Old Feb 6, 2004 | 12:57 PM
Colonel's Avatar
Old Fuddy Duddy
Ok
I found the Enkei rims I like...but they are NO where NEAR 4500 bucks. So does someone else make Enkei Rims? Knockoff? Similiar?
But I have found them with tires for much less here...
GunMetal Type Color MM2 18X7.5 Rims 197.00
Silver Type Color MM2 18X7.5 Rims 197.00
GunMetal RPM 18X8 275.00
Knowing I am opening myself up to critisizm...what yall think I should get. Is 18X8 REALLy worth the extra bucks. Prices above only indicate per price. Those three links are the ones I am looking at.
Old Feb 6, 2004 | 01:24 PM
NT2SHBBY
2k2nyc has 18x8 Enkei RPMs and loves em...here is a pic of them on his whip-
Old Feb 18, 2004 | 09:53 AM
Colonel's Avatar
Old Fuddy Duddy
Hmmm, those look "silverish". True? The place I was looking at them at...the only "color" they have is HyperBlack. I have a Sterling Mist colored car an not sure how HyperBlack would look..?
Where did he "aquire" his?
Old Feb 24, 2004 | 08:15 PM
96_vqmax's Avatar
You will love those Enkei RPM2,here's a pics of my Grey lustre Max with 18x8,245/40/18 Nitto 555.It weight in 19.4 lbs for the rim.
Old Feb 25, 2004 | 08:19 PM
Colonel's Avatar
Old Fuddy Duddy
How do you think those gunmetal colored rims will look on a sterling silver?
MAXSE5SPD
Aug 23, 2015 12:06 PM
thebull
Feb 2, 2001 05:38 PM
metallic97gxe
Dec 29, 2000 07:25 AM
metallic97gxe
Oct 23, 2000 02:04 PM
Gotrice4
Sep 27, 2000 09:53 PM
