Widest tire size to fit on 95 GLE Stockers?
Old Jan 21, 2004 | 07:21 PM
MaximaEvolution's Avatar
What's the widest that i can go on my stock GLE rims. It's a '95 and they are the "Honeycomb" rims. I don't want to get rims yet because there are more important things to upgrade! I want some go, not so much show. (Rice Killer)
Any help would be greatly appreciated, thank you.
Old Jan 27, 2004 | 10:05 AM
95Max's Avatar
The stock honeycomb rims are 6.5" wide so the largest tire is a 225/60/15
Old Jan 27, 2004 | 12:33 PM
DAVE Sz's Avatar
Hooooooonda.....
um, no. The stock tires are 205/60/15, so replacements would be 215/55/15 or 225/50/15 to keep you speedo as accurate as possible.
Old Jan 27, 2004 | 07:10 PM
95Max's Avatar
um, yes....Stock tire is a 205/65/15 which has a diameter of 25.4"
225/60/15 has a diameter of 25.5
Old Jan 27, 2004 | 09:41 PM
DAVE Sz's Avatar
Hooooooonda.....
stock tire is 205/60/15, just go here http://www.miata.net/garage/tirecalc.html to see which would change the speed ratio the least. I was wrong though, 225/55/15 seems to be the closest match.
Old Jan 28, 2004 | 08:33 AM
95Max's Avatar
The 1995/96 stock GLE tire is a 205/65/15 not a 205/60/15. The Stock SE tire is 215/60/15
Specs can be found at http://www.geocities.com/jgadlage/maxspecs.html
Also I have a 95 GLE and the stock tire is 205/65/15
MR2 T'd
Jul 9, 2021 05:06 AM
minsbang
Sep 11, 2015 08:48 PM
jfl330
Sep 4, 2015 01:44 PM
