17" x 7" Rims - Out of wheel wheel? Flush?
Old 01-22-2004, 09:58 AM
ReddoG_Max's Avatar
I am just wondering if I picked up some 17" x 7" rims with P215/40R17 tires how they will look from the side view of a 1998 maxima. Would they be flush with the body? indented or out alittle?
From most pictures they seem flush...but just checking.
ReddoG_Max is offline
Old 01-22-2004, 08:19 PM
6SPD_HLSD's Avatar
It will depend on the offset you'll get. I'd get 17 x 8.
6SPD_HLSD is offline
Old 01-22-2004, 08:35 PM
Clay Aiken has fancy genitals
asu174's Avatar
215 40 17? That's a Civic tire size. They will look crappy, especially with no drop. they will exaggerate your wheel gap, as well as look sucked in.
asu174 is offline
Old 01-22-2004, 08:45 PM
I tend to get a bit irritable
Pearl96Max's Avatar
Originally Posted by asu174
215 40 17? That's a Honda tire size. They will look crappy, especially with no drop. they will exaggerate your wheel gap, as well as look sucked in.
Which Honda does that come on? I know of 225/50, but not a 40.
--Don
Pearl96Max is offline
Old 01-22-2004, 09:26 PM
asu174's Avatar
--Don
Sorry, I probably should have clarified......
215 40 17 is the tire size that you put on Honda Civics with 17" aftermarket wheels. Basically, all the cheap wheel packages you find ANYWHERE have 215 40 17s because they are for Civics.
asu174 is offline
Old 01-22-2004, 11:40 PM
NYCe MaXiMa's Avatar
40 is way too short of a profile on our cars and 17" wheels.
17s should be 45, 50 tops..
18s should be 40, 45 tops..
go with 215/50/17, 225/50/17 or 235/45/17.. those will all work fine..
NYCe MaXiMa is offline
alahjahwan09
18
09-21-2015 09:12 PM
RWCreative
09-21-2015 11:01 AM
0m3nc0w
09-11-2015 05:21 PM
Violator
09-09-2015 10:14 AM
adamgalazka
09-08-2015 01:27 PM
Quick Reply: 17" x 7" Rims - Out of wheel wheel? Flush?
