20in Rims? Will They Fit on a 97 Max?
Old Jan 30, 2004 | 11:16 AM
NEmax97's Avatar
im Thinkin bout pickin up a set of 20in Giovanna Capri's but i dont think they are gonna fit. i was thinking about rolling my wheel wells but i dont know. anyone have any ideas on how i could make them fit?
Old Jan 30, 2004 | 01:02 PM
Iron Scimitar's Avatar
Tha Snatcher
20s on a 4th gen? don't do it to yourself man.
Old Jan 30, 2004 | 02:11 PM
limsandy's Avatar
As with all wheels, you need to know the dimension/size and offset. I have seen a guy here with 20" wheels on his 4th gen. So to answer your question yes, with the right size, offset and tire size.
~limsandy
Old Feb 1, 2004 | 02:51 PM
BLACKonBLACK98's Avatar
Former Vendor
The Capris will as long as they're the FWD offset (38). Recommended tire size is 225/35, but if you're not dropped you should be able to get away with 245/35. Contact me at on here or at www.20somethingwheels.com if you need any help.
Old Feb 2, 2004 | 06:34 AM
NEmax97's Avatar
So you say that they will fit but ....dont you think that they are going to rub?
Old Feb 2, 2004 | 10:19 AM
limsandy's Avatar
We, generally speaking, are saying that it all depends!!!
~limsandy
Old Feb 3, 2004 | 01:15 AM
white m3 guy's Avatar
they will not rub for sure with 245/35/20, if you put 255/35/20 with a 38mm offset they might rub when you turn but it wont be anything harsh it will even sand down that end
Old Feb 3, 2004 | 10:05 AM
foetray's Avatar
Should fit fine with 225/35/20 or 245/35/20.
Old Feb 5, 2004 | 09:45 AM
azmaxipad's Avatar
yes they will fit I'm gettin ready to do 20" rims on my 4th gen 96 w/ a 35mm offset. it all depends on lowering, tire size, and offset. I put 22's on a maxima at my work last week. stock height looked dumb IMO but fit w/ no rubbing
Old Feb 6, 2004 | 09:25 AM
RR95SE's Avatar
Foetray's right. I just put 20s on my maxima with a 45 mm offset and 245/35 tires. No rubbing on my car, but it's bagged.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
