going from 18 lb wheel to a 31 lb wheel
Old 02-06-2004 | 12:50 PM
Nismo's Avatar
My rota 18x7.5s weight about 18 lbs and theres a wheel I been thinking about that are 18x8 but the thing is that they weight 31 lbs each. how much worse will that be? how slow will that make it? I wont be drag racing in these but just for daily driving and occasional acceleration fun is what Im worried about.
Old 02-06-2004 | 02:22 PM
mitch33x's Avatar
holy are you getting some chrome 22's????
they will def take away some of that VI power
Old 02-06-2004 | 02:28 PM
Jeff92se's Avatar
I'm needing a caw
18x8s. Yes you will definately feel the difference. Not too much. I would describe it as maybe the difference the intake would make. Or a little less than when you use the AC. Something like that. 31lbs is ALOT heavier. I felt a difference from going from my stock 15s to the 17x8s I have now. These rims are only about 20-22lbs each.
Old 02-06-2004 | 03:13 PM
limsandy's Avatar
It's like adding approximately adding 416 lbs of weight.
~limsandy
Old 02-06-2004 | 04:02 PM
Nismo's Avatar
the wheels I was looking at were ASA ST3 which are supposed to be comming out march 31st according to the tirerack guy I talked to. More luxury than performance I guess.
Old 02-06-2004 | 04:05 PM
Jeff92se's Avatar
I'm needing a caw
IMHO, they don't look good enough to weigh that much.
Old 02-06-2004 | 07:30 PM
Nismo's Avatar
I guess I might have to seach around for a lighter set of wheels.
The thing is Im trying to get away from the sporty race wheel look and go for a classy luxury oem'ish style look. Borbet typeE was another option but they are only in 17s
coolsun
Wheels/Tires
10-15-2015 10:52 PM
Cipitiox
Wheels/Tires
09-30-2015 06:16 PM
Andy29
09-29-2015 05:32 AM
Garrettz459
09-28-2015 02:50 PM
Quick Reply: going from 18 lb wheel to a 31 lb wheel
