Drives Side tire has a bump in it?
Old Feb 1, 2004 | 09:25 AM
Sy0p's Avatar
Man its weird my Tire on the drivers side has like a bump in it on the side of the tire and ummm i was wondering is there any way to fix it and is it safe to drive on, i think its getting like a little bigger witch each cuple weeks is it going to pop?
Old Feb 1, 2004 | 09:28 AM
sadice's Avatar
i doubt there is a way to fix it and if u have extra money get a new tire... cause it might pop on u IMO.. u can probably get a used tire for like 25-30 $ or buy a new one up to u ...
Old Feb 1, 2004 | 09:43 AM
Sped's Avatar
Change that tire as soon as you can otherwise you can have a pretty bad blowout. I dont recommend driving on it too much if you can avoid doing so.
Old Feb 1, 2004 | 09:48 AM
KsuMax's Avatar
Cheesing away...
Bubbles in tires are no good. Change it asap
Old Feb 1, 2004 | 10:13 AM
driver824's Avatar
no way to get it out.. go to where u boguht the tire from.. should replace... it is a tire manufacter defect..
blake
Old Feb 1, 2004 | 11:35 AM
ManualMaxima's Avatar
5th Gen till she dies!
a bump in a tire is usually caused form a road inpact. like a pothope or those little ywllow reflective bump ****ers in the road, that i ruied many tires on. The sidewall of your tires is weak and the **** inside on the sidewall broke. have it checked out
Old Feb 1, 2004 | 12:40 PM
Sy0p's Avatar
Yea i orderd a new tire it sholud be here liek monday or tusaday so ill have it installed at the biginning of the week
Old Feb 1, 2004 | 11:21 PM
Ammi's Avatar
350 Detroit Muscle
Good. Very unsafe driving w/ those tires.
Old Feb 2, 2004 | 05:37 AM
Sy0p's Avatar
my freind said somthing that my tire has steel belted "somthing" that it dosent have a tube its a
Sumitomo HTR+ and he said that the bubble wont pop...
Old Feb 2, 2004 | 08:38 AM
Ammi's Avatar
350 Detroit Muscle
Most tired nowadays are tubeless.
Old Feb 2, 2004 | 11:01 AM
Sy0p's Avatar
so is it ok to drive for a little morse lol my credit card got rejected....
Old Feb 2, 2004 | 12:36 PM
AscendantMax's Avatar
if the bump is getting bigger as time progresses then get it changed asap. you're just pushing your luck for a blowout.
Old Feb 2, 2004 | 06:15 PM
Ammi's Avatar
350 Detroit Muscle
Every bump or potholes will make it bigger. Soon enough, the tire will blow.
Old Feb 2, 2004 | 06:55 PM
kwd2kSE's Avatar
Have you heard the old saying "You're putting your life in jeopardy". That's exactly what you're doing.
Old Feb 4, 2004 | 10:20 AM
wariow's Avatar
hey there, I have the same problem with the a bubble in my driver's side tire. Now I'm thinking of replacing all for of the OEM tires that came with the car. Will Nissan warranty cover it because it looks like there's some good tread left in these tires. But I have no receipt for these. How many years of warranty do these crappy OEM tires have? I don't wanna fork out 300+ for 4 new tires and mounting and balancing.
Old Feb 4, 2004 | 08:09 PM
Ammi's Avatar
350 Detroit Muscle
Nissan won't cover tires
Old Feb 4, 2004 | 09:57 PM
Sy0p's Avatar
im getting it changed tomarrow i just hope those ****ers dont scrach my rims
Old Feb 5, 2004 | 06:58 PM
sadice's Avatar
heh me with advice i got one too on pass side two days ago now got to change it......
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
