2k2 and 2k3 se 17x7 in rim, what is the offset?
Old Feb 2, 2004 | 10:52 AM
wojowojo16's Avatar
Old Feb 2, 2004 | 10:54 AM
PAPA SMURF
either 42 or 45
Old Feb 2, 2004 | 11:17 AM
wojowojo16's Avatar
Thanks, I was trying to figure out how much more the 2004 maxima se rim would stick out from the OEM 2002 se rim. seems to only be about 1.1 cm, then add another CM or so for the larger tire.....
Old Feb 2, 2004 | 11:20 AM
PAPA SMURF
04 SE rims are like 30mm offset
Old Feb 2, 2004 | 11:37 AM
wojowojo16's Avatar
Just called tire rack, 04 rims are a 35mm offset. They would stick out 16mm farther that the 02 se rims...
TallTom
57
Oct 14, 2025 05:16 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
