Ok I got some 19's by 8.5 rims...what tire size is recommended 245/35/19 or 245/40/19
Old Feb 10, 2004 | 08:31 PM
K Pazzo 6's Avatar
remember i live in chicago & drive downtown alot so i hit a few potholes ever so often.
also 1/4" spacers were included w/ my rim buy so the 245 series i believe shouldn't rub?
thanks
Old Feb 10, 2004 | 08:32 PM
Ammi's Avatar
350 Detroit Muscle
your offset?
Old Feb 10, 2004 | 08:39 PM
K Pazzo 6's Avatar
Originally Posted by Ammi
your offset?
+35 Offset
Old Feb 10, 2004 | 08:44 PM
Ammi's Avatar
350 Detroit Muscle
how much did you lower your car?
Old Feb 10, 2004 | 08:56 PM
K Pazzo 6's Avatar
never measured....i'm on h&r springs
Old Feb 10, 2004 | 09:06 PM
Ammi's Avatar
350 Detroit Muscle
well, i know someone who had rubbing issues (rear) running 18X8.5 40+ offset w/ 255/40/18 tires.
Old Feb 10, 2004 | 10:08 PM
K Pazzo 6's Avatar
well i'm thinking 245 not 255.....
Old Feb 11, 2004 | 03:25 AM
CCx's Avatar
CCx
For what it's worth, I was told my 19x8.5 +35 offset would fit fine with 245/35/19's, no rubbing. Waiting until warmer months to actually put them on so I don't know for a fact yet.
Old Feb 11, 2004 | 04:59 AM
Ammi's Avatar
350 Detroit Muscle
Not much difference between the two. Little bit wider and little bit taller.
Old Feb 11, 2004 | 10:12 AM
limsandy's Avatar
Hmmm, that's weird because I don't think it's gonna rub. Then again, I might be wrong. He must be lowered by 3 inches?
~limsandy
Old Feb 11, 2004 | 10:48 AM
Ammi's Avatar
350 Detroit Muscle
~limsandy
Nope. Eibach Pro Kit. He had to grind the fender down a little bit
Old Feb 11, 2004 | 02:51 PM
limsandy's Avatar
K Pazzo 6,
to answer your question, yes 245/35/19 will fit perfectly on those HP Evo wheels.
~limsandy
Old Feb 11, 2004 | 07:26 PM
Ammi's Avatar
350 Detroit Muscle
You might have rubbing issues and you might not. Only way to find out is trying them I guess.
Old Feb 11, 2004 | 08:28 PM
asu174's Avatar
Clay Aiken has fancy genitals
You'll be fine with 245. 255 will probably rub.
Old Feb 12, 2004 | 06:54 AM
NT2SHBBY
245/40/19 for that lil extra ride cushioning is the way id go
Old Feb 12, 2004 | 10:15 AM
limsandy's Avatar
That extra rubber will be rubbing.
~limsandy
Old Feb 12, 2004 | 11:16 AM
NT2SHBBY
~limsandy
talk to Nathan-he's running GC's and soon to have 245/40/19's....
I can tell you I would clear that size no problem with my maxspeeds and if it weren't for that size being sooo much $$$$ I would have them also
35's are just too thin for areas with not so nice streets
also FYI limsandy-my boy 2k2nyc has 245/45/18's which would be damn near close to 245/40/19 and he dont rub-on H&Rs and he's got plenty of room left
Old Feb 12, 2004 | 11:34 AM
CCx's Avatar
CCx
If that's the case, that would be great news and I'd gladly order 245/40/19's in April instead of the 35 series tires (Philly roads....ehhh...notsogood ) - my drop will be moderate (Tein H.Tech ~1.6"), so hopefully no rubbing issues but would like to get that ironed out before the purchase....otherwise I'll just say screw it, get the 35's, and hold my breath from May through October
Old Feb 12, 2004 | 12:03 PM
NT2SHBBY
go for it..you'll be fine...just dont get scurred when you see $230+ prices on tires
Old Feb 12, 2004 | 03:46 PM
K Pazzo 6's Avatar
well i'm getting 245 for sure.
just needed to know if i can run 40 series w/o rubbing since i drive alot & might possibly hit a pothole ever so often cause some roads in chicago suck....like 'nt2shbby' said, for that "extra ride cushioning"
Old Feb 12, 2004 | 07:13 PM
BLACKonBLACK98's Avatar
Former Vendor
225/35 for stock outer diameter
Old Feb 13, 2004 | 06:31 AM
NT2SHBBY
pazzo-do it and dont worry bout it..ur on H&R...my homie 2k2nyc is on 245/45/18's & H&R on his 2k2 which drops lower than ur 2k-2k1 and he is fine with some inches to spare....
*** the speedo error and go for it!
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
Johnny9595
Sep 16, 2015 07:20 PM
sdotcarter
Sep 2, 2015 09:53 PM
