19x8.5 rims what offset???
Old Feb 23, 2004 | 12:12 PM
2001MaximaSe's Avatar
I am selling my 18's and I am getting 19x8.5 with 245/35/19 tires. I want to go with 35mm offset but I am worried about rubbing. Anyone with 19's can you let me know what your running. Thanks
Old Feb 23, 2004 | 12:33 PM
CCx's Avatar
CCx
From what I've been told, 35mm will not be a problem with 19x8.5 - my wheels are 37mm offset (not installed yet), 19x8.5, and the car will be lowered 1.5", should present no problems.
Old Feb 23, 2004 | 09:57 PM
Hamy's Avatar
35mm will fit fine in the rear...but in the front it might be close. How low is your car? I've found that the perfect setup lowered on Tein STechs would be 40mm in the front and 30mm in the rear with a 19x8.5 wheel. That makes them look nearly even without and rubbing. You will need to get your wheels in 40mm offset and run an H&R 10mm spacer in the rear to make it work. Thats just my knowledge from what I've done with my car so...take that for what its worth.
Old Feb 23, 2004 | 10:01 PM
Triple8Sol's Avatar
I miss the .org!
I'm rolling 19x8 with 245 rubber all around. 35 offset in the front, effective 30 offset in the back. No rubbing. Oh and I'm on Tein S. Techs.
Old Feb 23, 2004 | 10:02 PM
limsandy's Avatar
Originally Posted by slammed95
The front might stick out a little and rub a tiny bit, but the back will be perfect.
....... what he said.
I know someone who has 19x8 wheels with 35mm offset and 245/35/19 tires, lowered with Tein springs, and no rubbing.
~limsandy
Old Feb 24, 2004 | 04:13 AM
thanks guys I have progress springs on right now so I think it should be fine. Thanks for the info
Old Feb 24, 2004 | 11:16 AM
maximamaybe's Avatar
t56gen3 has ADR M-Sports in that size and has no issues. It looks awesome also. Here are a few pics.
Old Feb 24, 2004 | 12:14 PM
thanks that is definitly hotttt
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
MplsMadMan
Sep 11, 2015 07:54 AM
