Kumho Ecsta MX reviews...
Anyone tried them?
I need new tires this spring. Would rather not spend close to $200/tire if I don't have to. I've been using 712's for a few years and have liked them, they were quite good for the price.
But, for about $30/tire more I can get the MX's. I'm open to other suggestions as well (need 235/45/17 tires).
I can't put any wider on a 7.5" rim, can I?
Thanks.
Thanks.
They're getting fantastic reviews in autox community. Fantastic dry grip, decent wet grip, and they don't overheat easily. As good as the BFG KD's and possibly better than Falken Azenis. For a "Max" performance tire they probably can't be beat.
Both Natl Tours this year were won by STS on MX's sofar over the Azenis.
http://www.scca.org/amateur/solo2/na...lts.html#Other
http://www.scca.org/amateur/solo2/na...rs/results.pdf
I've also heard they're good from reading other forums. IF you're looking for a more hardcore performance tire, that is. Keep in mind the tradeoffs as these tires are designed more towards the "competition" side of the market than the 712's are.
Originally Posted by maximamaybe
I got around 20,000 on my last set. But decided to stick with them again. I plan on upgrading to 19s in the near future. When I do that, I am going to try Nittos
mx's any good in the snow? im lookin at sumi htr+ but a couple of people on the org are complaining about the bubbling on the sidewall..and my firend who lives in ny got one too recently on his ..still debating
MX vs Falken Azenis Sport... Those are on the top of my list right now. I had the 712 and was thoroughly unimpressed. Braking stood out as the worse characteristic. Acceleration was 2nd, since I could spin them quite easily. As for taking turns, they squeel early but broke progressively.
I'm on Azenis Sports right now and have no complains, except for poor wet weather traction, but that's a given with DOT approve race tires. MX won't be much better. The only reason I'd consider MX is the 235 size that Falken does not carry. However, Falken's edge is quite square compared to MX, so you're probably putting down the same amount of surface area.
Don't take TireRack testimonials too seriously... the 712 were highly rated and the reviews were glowing... but I personaly didn't like them. I guess if you don't push your car hard very often, they are excellent tires, like the HTR+.
Jae
Jae
I would never take an MX or Azenis Sport in the snow. Maybe with snow chains, but why chew up a set of "track" tires?
If you're thinking of going snow, then All-Seasons should be considered. However, the best all-season tire will not compare to an equivalent summer/track tire. Having 2 sets of tires is a good idea and switch them seasonally. You shouldn't be going 9/10ths in poor weather anyways, so the MX is useless in winter.
Jae
MarkG98SE
20
04-20-2001 10:37 AM
