who has 19's...w/ the lowest offset?
There was a Maxima with 19x9.5 with Enkei Aegis. I believe those come with 45mm offset, so he must have used wheel spacers. I myself are going to put 19x9.5 wheels with 35mm offset at the back and I'll let everyone know how they'll fit.
~limsandy
~limsandy
Originally Posted by Hamy
I have 19x8s with a 45 offset...but I have 5mm spacers in the front and 15mm spacers in the rear. So 40f/30r dropped on S. Techs with no problems. Infact I wish I would have went with the 8.5" wide wheels.
Originally Posted by slammed95
That'll most likely rub. 38-40 would give better clearance.
Yeah, but what can I do? I fell in love with those wheels. At most, I'd just have to trim or hammer away my fender for a little bit.
When you say they're gonna rub, you mean the front or the back or both?
You can get wheel spacers here: www.optauto.com
~limsandy
~limsandy
~limsandy
What type of wheels are you getting? That sounds like its going to be a sick setup. I'd have to say from my fairly small knowledge of offset vs. width that it will just fit without rubbing. And even if you do have to trim it a little, who cares by the sounds of it your going to have one hell of a nice setup.
Thanks, Hamy. I guess nobody knows for sure if my wheels are going to rub or not, since no one has reported having those sizes.
~limsandy
That will not work. You'll need something like 40-45 offset in the back, and even then it might rub depending on your drop and certain driving conditions. That wide of a wheel def won't work in the front...
Originally Posted by Ammi
Someone was running Axis Hiros 19x8.5 w/ 35mm offset and no rubbing issues according to him.
Originally Posted by WildmanAL
Yeah Nathan has those, but I'm just trying to find another wheel because they're going to be on backorder for a really long time. The TSW Thruxtons come in 40 and 20mm offsets and I was wondering if I could squeeze in the 20. I'm not sure how these clear big calipers, but I just ran across them tonight and it made me wonder. They're also like $400 cheaper than the Hiros. I could get the Hiros in silver right now, but I want the grey finish.
A little update on this thread....I've been through 2 cars since I first posted here but...I later on ran 19x8.5 and 19x9.5 staggered on my Maxima. Offsets were 35 front 30 rear. I even ran a 5mm spacer in the rear with out a problem. Pics:
So your saying you ran a 25mm offset in the rear including the spacer?
Originally Posted by Royal_T
**BUMP***
1fstmax, I wanted to know what do you have for the front? And do you have any rubbing issues? I have Tein Basic Coilover setup do you think I'll rube with this setup.
im not sure about the tein basic's... the fronts are 19x8.5" 34mm offset.. they have no issues..
I might do that setup w/ 19x8.5 35mm offset front and 19x10.5 35mm offset rear. I hope i don't have any issues w/ volk racing rims. Also what size tire are you running in the rear?
Originally Posted by Triple8Sol
(revival)
+1 ........................
