What is the Best tire size for ...........
Old Mar 21, 2004 | 11:07 PM
Kevon1's Avatar
What is the Best tire size for 17 x 8 rims 40mm offset? Tire rack recomends 215/50/17 is there not a bigger or should I say better tire size to run on this size rim? Can we run 245/45/17 tires safely on 5th gen max with this size rim?
Old Mar 21, 2004 | 11:18 PM
SEmy2K2go's Avatar
Go BUCKS!!!
By the tire size and questions your asking, I'm assuming you're asking about the OEM wheels. Those are 17x7 and widest I've seen that guys are using are 235/45/17's. OEM size is 225/50/17.
Old Mar 21, 2004 | 11:23 PM
Kevon1's Avatar
Actually no......
No they are not factory wheels. They are 17 x 8 40mm offset 5x114.3 lug pattern by Mille Miglea.
Old Mar 21, 2004 | 11:24 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I would think that you would be able to use 245/40/17 or even 245/35/17's in that case.
Old Mar 22, 2004 | 03:43 AM
limsandy's Avatar
Use 235/45/17....
~limsandy
Old Mar 22, 2004 | 04:05 AM
03BlkSETE's Avatar
I have 17 by 7.5 and can safely run 245/45/17 and so can you. Plug your rim size into the calculator i the link below to get a good idea of what you could run. Their used to be a great Tire and Rim Association chart available but the link doesn't work any more.
http://www.1010tires.com/TireSizeCal...?action=submit
Old Mar 22, 2004 | 04:06 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by limsandy
Use 235/45/17....
~limsandy
Yep, limsandy is right...I just found some wheel/tire packages where 17x8's come with 235's. Thanks for the correction.
Old Mar 22, 2004 | 04:10 AM
ZIPPIN's Avatar
Mauja He Mauja
Use 235/45/17....
~limsandy
anyone tried that size on 18's?? we have bad roads here in indy. very bumpy. i am getting some 18's, but do not want 35 or 40. do you think it would rub with 45's?? i have 55's on stock 17's. helps with the wheel gap too. but i am lowering it when i get wheels...
Old Mar 22, 2004 | 10:57 AM
limsandy's Avatar
I dont know...... you can get away with it, but I highly recommend 235/245/255 with 40 series size for 18" wheels.
~limsandy
Old Mar 24, 2004 | 08:02 AM
Kevon1's Avatar
Thanks for the help.
I decided to go with the 235/45/17 Pirelli P Zero Nero m/s due to the excellent ratings in tire rack .Limsandy thanks for the know how.
Old Mar 24, 2004 | 08:12 AM
Ammi's Avatar
350 Detroit Muscle
Good choice
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
