Pics of 18inch G35 wheels and/or 350z wheels on a 5th Gen
as long as the rims are the same size (not staggered like a 350Z) they will work. If they are staggered you won't be able to rotate your tires.....FWD vs RWD doesn't matter, since you rotate your tires anyways.
check my cardomain page
http://www.cardomain.com/memberpage/436374/2
Originally Posted by soonerfan
G35C are staggered. 1/2 in wider in rear.
but you can use the same size tires on all four so you can rotate
not the smartest thing to do, but it can be done
G35C wheels on a non-dropped maxima doesnt look good in my opinion. You gotta drop the car and then it will look much better with those rims on.
The inch gap on the stock G35C makes it look real nice with those wheels
Yeah, the G35 wheels are not staggered. All four are 18x8. Only the tires differ. I'm probably going to go with some 235/40-18's all around so I can rotate them with ease.
2001SE, you have a point & yes, my Maxspeeds are on the way, can't wait!
Originally Posted by AKANeedles
pablosal ,Those rims look good.It would look much better when you drop it.Where did you get the rims?How much?
I have the 350Z wheels on... They will actually be going on sale once i get my new wheels. (approx end of april). they are all 17X8. I dont have the staggered setup. I bought 4 rear wheels so I can rotate them. More pics on my page
I just noticed you were in Houston.
Your car looks somewhat familiar ? !
Have you seen my maxima before? Click on this link for pics I just posted few mins ago..
http://forums.maxima.org/showthread.php?t=300172
http://www.nissanforums.com/showthread.php?t=47141
havent seen you max before... what side of town are you at? Im in sugarland. you should come to one of our meets. Im part of HNE. PM me if youre interested in going to one of our meets.. we have one every month. actually, this month is coming up. its on april 10. we are meeting at a drifting event. heres the link
Im just not sure if Ill be in my Maxima or my SRT-4 =P
Maybe Ill see you guys out there !
Originally Posted by 2001SE
5 spd ...your car literally looks like a 4x4, gotta drop that thing and get some low profile tires
my breakover angle aint that great, but it's great for rockcrawling, especially the loose stuff. right now I have the stock suspension, and will look into getting a set of coilovers soon. as far as the tires go, I dont want to put in the money just to get thinner rubber. I am frugal and will wait unti these tires wear out.
G35 18X8 Wheels with a +30 offset and Maxspeeds spells trouble. It appears that you may run into a rubbing problem. From My understanding, you can't go below a +35 on an 8" wheel. If this thread is correct in that the offset of the G35 18x8 is a +30, then I see trouble coming your way.
Good Luck, I hope that I am wrong or your offset isn't a +30.
Yeah, when I get my springs, I'm going to go with 235/40/18 all around to avoid rubbing & I'll also buy some new shocks and install them all 3 at once. There's a nearby customizing shop, KMP, and I'll schedule something with them. Then its straight to Alignment Plus!
