16x8.5 on 4th gen...
Old Apr 14, 2004 | 09:02 AM
geo1317's Avatar
16x8.5 with a 37 offset using 245/50 16 or even 255/50 16. Will this fit a 4th gen?
Old Apr 14, 2004 | 12:46 PM
geo1317's Avatar
Originally Posted by slammed95
Those tire diameters would be too big, and the sidewall on the would just look rediculous.
Even with 235/45/17's, sidewalls look too big.
With a 37mm offset, 245's will sit flush with the front fenders, and will be just a tiny bit recessed in the rear, but they won't rub on the fender lip.
these are 16's so i do expect the big side walls, but looks are least important if i go with this set up.
Old Apr 14, 2004 | 03:11 PM
z32drifter's Avatar
what about a 245/45/16........ you get the same cross section with a sidewall a little shorter than a 225/50/16...... if you are looking for performance I think it would be a better choice.....my .02
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
ik95
Sep 16, 2015 08:11 PM
