guys with milliena wheels LOOK..
Old Apr 19, 2004 | 11:44 AM
RI-Max's Avatar
im getting the millienia wheels 15/6 when i go up 2 import war may 1st. i was think about getting 235/60/15..bf drag will that fit???? what sizes are u guys using????
Old Apr 19, 2004 | 12:54 PM
Matt93SE's Avatar
STFU n00b!
before you mess with drag radials, I'd do a bit of work on your driving. with those mods, you should be low-mid 14s on crap tires. adding drag radials to the mix will just make it harder to drive properly
Old Apr 19, 2004 | 01:23 PM
RI-Max's Avatar
i do have 165,000 miles on it...
but 2 answer my ? is that a good tire size???
Old Apr 19, 2004 | 02:10 PM
2k1maxgle's Avatar
just get some mickey thompson 22x8 drag slicks, i think thats what blubyu2k2 and sr20den use on their 5th gens. Dont hold me for that tho....because im not 100% sure....
Old Apr 19, 2004 | 04:31 PM
RI-Max's Avatar
naw i want drags.. thanx tho
Old Apr 19, 2004 | 11:56 PM
2k1maxgle's Avatar
MT 22x8s are drags...they are drag slicks, even stickier than drag radials....
Old Apr 20, 2004 | 03:32 AM
BEJAY1's Avatar
Conecarver
As to your question - no they won't fit. Assuming you're talking about the BGF Comp TA Drag radial that 235 is too wide - 6.5" min rim. They do offer the g-Force TA Drag radial in a 225/50 that will fit. You might wanna check on the weight.
Old Apr 20, 2004 | 02:11 PM
RI-Max's Avatar
225/50 would fit...
whats do u mean check the weight??
where do people get the MT slicks 22x8??? links cheaps???
Old Apr 20, 2004 | 07:44 PM
2k1maxgle's Avatar
225/50 would fit...
www.jegs.com look under Mickey Thompson ET Drag, they are 22x8 for a 15" wheel. Im pretty sure they fit just fine, i think blubyu2k2 used them a few times and he had them on Millenia wheels as well. I know someone had these on some 15x6.5 wheels.
Old Apr 21, 2004 | 04:39 PM
Nealoc187's Avatar
SLOW
MT 22x8" slicks will not fit on 15x6" millenia wheels, they are too wide for the wheel. A 235 tire is also too wide for the wheel.
Old Apr 21, 2004 | 04:58 PM
RI-Max's Avatar
casue my friend had a 235/60 on a 15/6 rim??? what should i get the 225/50 i guess
Old Apr 21, 2004 | 05:50 PM
CullenJ76's Avatar
I have some 205/50 15 Drag radials(BFGoodrich Gforce) for sale. PM me if you are interested
Old Apr 22, 2004 | 04:54 AM
2k1maxgle's Avatar
I would go with the widest thing possible that will fit on the 15" wheel. I thought the Millenia wheels were 15x6.5?? anyway...the 225/50 should work great....let me know how what you end up getting because im looking for a similar setup as well. I am probably gonna use some 1993 Infinity J30 15x6.5 (anybody got any clue on how much these weigh??) wheels with prolly a BFG G-force T/A drag radial. I know the Infiniti wheels weigh a hell of a lot less than my 18s....i test fitted a pair of the Infiniti 15s and they work great, traction sucks with street tires but other than that they should be a great track wheel if i get the right drag radial on it.
Old Apr 23, 2004 | 01:19 PM
RI-Max's Avatar
CullenJ76
naw i want wider thanx tho
Old Apr 23, 2004 | 01:43 PM
CullenJ76's Avatar
no problem. I think I have them sold to a local honda owner. It's slicks for me
maxipower
Aug 21, 2015 11:10 AM
Economic_Rage
Aug 20, 2015 08:27 AM
twotonezed
Aug 16, 2015 11:41 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
