tire question for the gurus
Old May 5, 2004 | 02:27 PM
mclee45's Avatar
will 255/45/18 tire fit on a 5th gen maxima. i know 245/45/18 fit fine with no problems but i want to get 255/45 series tires ifthey fit. anyonerunning on this size?
Old May 5, 2004 | 03:34 PM
limsandy's Avatar
Go with 255/40/18. Your handling will most likely suffer, depending on your choice of tires. 255/45/18 is for 6th gen.
~limsandy
Old May 5, 2004 | 04:37 PM
Larrio's Avatar
The Definitive AE Master
offset is also important in relation to the maximum tire size you wanna run
here is mine with 265/45, 38mm offset 17x9
Old May 5, 2004 | 05:04 PM
Ammi's Avatar
350 Detroit Muscle
Yes it will fit. Make sure you get rims w/ correct offset though
Old May 5, 2004 | 05:44 PM
limsandy's Avatar
Originally Posted by slammed95
Come on Larry, that's 265/40 and 25mm offset.
Since that fits, then pretty much anything will fit on the front.
Uh..... he has 25mm offset all around? For real?
~limsandy
Old May 5, 2004 | 06:53 PM
Larrio's Avatar
Old May 5, 2004 | 08:44 PM
mclee45's Avatar
offset is +38mm.... im also planning on getting 5mm spacer which will make the total offset +33mm.. will +38 and +33mm offset work?
MR2 T'd
Jul 9, 2021 05:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
videomano
Sep 8, 2015 03:28 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
