Shaking steering wheel
Old Jun 28, 2004 | 02:57 AM
02GLEMax's Avatar
I have a question I have the 512's on my car and have had them balance twice and still have a slight shake in the steering wheel. It isn't terrible but enough to tell it is there. What could this be?
Old Jun 28, 2004 | 04:10 AM
MaxedOutOfCash's Avatar
Pizda Boy
is it when you're braking?
how old are the tires?
Old Jun 28, 2004 | 04:55 AM
95Max's Avatar
New tires?
Maybe crappy balance job. I had new tires put on my 95 Dunlop sp5000 and they caused a shake in the wheel. Had them balanced 2x by the same shop. The car was in Nissan a week later (different issue) and they said that they balanced the tires because they noticed a shake in the steering wheel. Picked up the car and no shake.
Old Jun 28, 2004 | 07:10 AM
02GLEMax's Avatar
Originally Posted by 95Max
New tires?
No isn't the rotors no problem with braking just had these tires installed about 2 weeks ago and it didn't do it before that. I think it is in the balancing
Old Jun 29, 2004 | 12:40 PM
Playero's Avatar
Sanduguero
Maybe they are bent already? Lets hope not
Old Jun 30, 2004 | 03:09 AM
02GLEMax's Avatar
I don't see how they could be bent when they never shook with the factory tires and haven't hit anything that hard in the road. I believe it is in the balance mainly due to you only feel it when you are at 45 mph or higher.
Old Jun 30, 2004 | 04:04 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Sure sounds like a balancing issue to me. Either that or you may have a tire that is out of round. I'd try a different shop to have the re-balance them and check for out of round.
Old Jul 1, 2004 | 02:00 AM
Norm Peterson's Avatar
Maybe the shop only did a static balance. Or maybe it's a nonuniformity in tread stiffness that a road force balance might correct.
Read this current thread: http://forums.maxima.org/showthread.php?t=320197.
Norm
Old Jul 2, 2004 | 07:27 AM
schernov's Avatar
Balancing issue. I had mine rebalanced 4 times, they had to replace 2 tire cuz they were "out of round", also are they using one of them RoadForce machines? If yes, ask them to balance to 1/4oz not 1/2 oz. Some shops get lazy...
Old Jul 6, 2004 | 03:33 AM
02GLEMax's Avatar
It was a balancing issue. If it if starts again I will take it to the dealer and have them do it.
Old Jul 7, 2004 | 09:57 AM
KnowledgeBorn's Avatar
Hub rings....they fixed my problem...
http://www.1010tires.com/hubrings.asp
Old Jul 7, 2004 | 02:00 PM
CTmax02's Avatar
I have the same problem the steering wheel vibrates when i'm going over 60 mph. I have size 235/45/17
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
