OFFSET Question
Old Jul 29, 2004 | 04:36 PM
MAXULUS's Avatar
OFFSET Question
What is a good offset for 17"x7.5" rims?
I was told no lower than 40mm and then I was told 35mm.
The rims I'm getting come in 35mm, 38mm, 43mm offset
I want the wheel to come out close to the fender not too much in and not stickin out.
Any help would be greatly appreciated!
Old Jul 29, 2004 | 06:30 PM
Mizeree_X's Avatar
Getting back to his roots
If that's the case, get a 38mm offset.
Old Jul 29, 2004 | 08:32 PM
phenryiv1's Avatar
Mod her. Ate her.
That was what I was going to say, even before i saw the post above, but that seals it, in my mind.
Old Jul 29, 2004 | 08:39 PM
GeSeKeE19-'s Avatar
35mm, no? wen i had 18x7.5's, i had 42mm offset and that was pretty in there...i was told a 10mm spacer from a 42mm offset would make it pretty dang flush...so, with that said, wouldnt a 35mm be perfect? well, just in case, go check the offset calculator...compare with 9.5" width rim with a 45mm offset or a 8.5" wide rim with a 40mm offset...thats a perfect flush for me!
Old Jul 29, 2004 | 08:40 PM
GeSeKeE19-'s Avatar
oops, didnt see that it was for a 4th gen max...my bad
Old Jul 29, 2004 | 08:43 PM
phenryiv1's Avatar
Mod her. Ate her.
2 OT replies to you: First off, I love your rims. Second off, PLEASE do not post your sig more than once per thread.
Old Jul 29, 2004 | 09:02 PM
GeSeKeE19-'s Avatar
sorry...bad habit...ill watch myself!
Old Jul 29, 2004 | 10:33 PM
BLACKonBLACK98's Avatar
Former Vendor
for 38mm
Old Jul 30, 2004 | 09:22 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Which offset do you have on your 19x8.5 in front?
Does it rub AT ALL?
What tires you got?
Old Jul 30, 2004 | 02:31 PM
GeSeKeE19-'s Avatar
i have 40mm offset on the 8.5's with 235 35 19, wish i had 245 35 19. and no it does not rub AT ALL! i have bfg scorchers...crap tires, but i didnt have the money for better ones...sucks
Old Jul 30, 2004 | 07:40 PM
mm347's Avatar
What about 45mm, would that work?
According to the wheel offset calculator:
The clearance from stut housing to the inside of the wheel will be 13mm LESS
The outside edge of the wheel will EXTEND an extra 13mm
Is this right?
Old Jul 30, 2004 | 08:04 PM
Mizeree_X's Avatar
Is this right?
The higher the offset, the farther the wheels are pushed farther into the wheel well. I dunno about that outside edge "extending" business, maybe they mean the gap between the fender edge and edge of the wheel will extend 13mm, which is true.
Old Jul 30, 2004 | 09:10 PM
mm347's Avatar
Do you think they would rub at all?
Old Aug 2, 2004 | 08:52 AM
IceY2K1's Avatar
Thanks.
That's a meaty rim/tire to have on front without any rubbing issues, especially while turning. Glad to hear it.
Old Aug 2, 2004 | 09:07 AM
{-_-}'s Avatar
i know that max can take +35-+45 offset... but of course, always better in the middle than the extremes.
Old Aug 2, 2004 | 01:01 PM
redstradic's Avatar
i would go with 38.
Old Jun 20, 2008 | 09:14 AM
hi-tek22's Avatar
so with a +38 offset, 245/35/19 tires and 19x8.5 Rims....most of you are not getting any rubbing?
I havent got any, yet (not that im aware of) and hopefully keep it that way
Old Jun 20, 2008 | 09:21 AM
NmexMAX's Avatar
dot dot dot ...
Why did you just bump a reallllly old thread?
Random postwhoring much? At least bump threads created in the past month.
Old Jun 20, 2008 | 10:43 AM
Former Vendor
right?
times have definitely changed, so many +38 recommendations.
Old Jun 20, 2008 | 12:55 PM
z32drifter's Avatar
Originally Posted by BLACKonBLACK98
right?
LOL I was going to but your ***** on a 7.5 +38, just shows we have learned alot about wheel fitments over the years.
Old Jun 20, 2008 | 03:28 PM
NmexMAX's Avatar
dot dot dot ...
8.5 / +18 For the rear. +27 / 8.5 up front in order to be flush.
Old Jun 20, 2008 | 06:16 PM
Former Vendor
it took me a minute to realize what had happened to. i thought it was a typo.
Old Jun 20, 2008 | 07:29 PM
NmexMAX's Avatar
dot dot dot ...
Where's love for my learning?
Old Jun 20, 2008 | 08:02 PM
Former Vendor
hows that for love?
Old Jun 20, 2008 | 08:05 PM
NmexMAX's Avatar
dot dot dot ...
ahhh
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
