Correct offset for 5th gen.?
Old Aug 6, 2004 | 02:09 PM
str8max's Avatar
OK I have been looking @ the HP EVO's 18" and they come in 38 offset but stock 17" are 45 offset.
What offset is the best for 18" on a 5th gen.?
I don't want to have to use spacers!!!!
Old Aug 6, 2004 | 02:37 PM
BLACKonBLACK98's Avatar
Former Vendor
i think alot of 5th gens use 38mm so the wheel fills the wheel well better. spacers won't be neccessary.
Old Aug 6, 2004 | 02:44 PM
str8max's Avatar
Well it must be different for 4 gen. cause a couple threads down i person is talking about smashing in his hub!!!
and what about this
http://www.cardomain.com/member_page...=391535&page=1
and this
Old Aug 6, 2004 | 02:50 PM
Hamy's Avatar
I think on the HP evo rims the offset is not the problem. Because the lip is so large the backspacing is a bit more than most wheels. Thats why you need a spacer to push it out from the hub so it doesn't hit the dust cap. On a 5th gen offset is really just a matter of how wide your wheels are. Perfect offset is between 35-38. But you can run anywhere from 30-45.
Old Aug 6, 2004 | 02:55 PM
str8max's Avatar
Hamy do or don't I need spacers?
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
leatherneck
Sep 30, 2015 09:16 PM
mpbclutch33
Sep 21, 2015 01:54 PM
